Im looking for a program that can play mpeg-ps streams(audio) without having to convert it to something else.
here is one of the streams.
General
Complete name : N:\AUDIO_TS\ATS_01_1.AOB
Format : MPEG-PS
File size : 1.00 GiB
Duration : 28s 811ms
Overall bit rate : 298 Mbps
Audio
ID : 189 (0xBD)-161 (0xA1)
Format : MLP
Muxing mode : DVD-Video
Bit rate mode : Variable
Maximum bit rate : 9 600 Kbps
Channel(s) : 6 channels
Sampling rate : 96.0 KHz
Bit depth : 24 bits
yep sure enough it does. thanks for the reply! I even tried it before and it didnt play. the only thing different is that I mounted it now with virtual clone drive and it works great!
capture and playback of udp streams
By tuxeric in forum Video Streaming DownloadingReplies: 3Last Post: 29th Mar 2012, 07:38 -
MPEG TS Streams missing LFE channel ?
By s1lenc0r in forum AudioReplies: 3Last Post: 17th Apr 2010, 10:20 -
what unit can playback hi def .ts (transport streams) from a sat receiver
By manikm in forum Media Center PC / MediaCentersReplies: 4Last Post: 29th Nov 2009, 16:46 -
Mux raw subtitle streams in a existing mpeg file.
By etvideob in forum LinuxReplies: 0Last Post: 14th Aug 2009, 03:22 -
Swap audio streams in MPeg-2
By billyygli in forum AudioReplies: 1Last Post: 10th Apr 2009, 10:31
