Hi,
I have been given a Panasonic Lumix US import. It is very good. I would like to burn the files using my Panasonic blue ray recorder but I cannot because AVCHD files are for NTSC US system.
I have a converter programme which allows me to convert them to other files with the 25images requried for PAL. However, Fi I do that and save it is HD MPEG4 and try to use the SD card in my Panasonic Blue ray it does not read the files.
I am an absolute beginner and I have very little knwoledge of all the technical issues. Can anybody help me in converting these files to PAL system and also to AVHCD compatible with my Panasonic Blue Ray PAL recorder? Maybe I can use my coverter to convert them to MPEG4 compatible with PAL. But then I need to convert them back to AVCHD for Panasonic.
Help, Help, Help
Have you tried looking through the camera's menu to change the output between NTSC and PAL?
Yes, but I have no such selection, I have also phoned Panasonic. As they are, the blue ray recorder plays them but does not burn them. I use Aunsoft software to convert the files to PAL compatible. It is OK to use the siles then on computer and burn them on regular DVD.
However, I would like to burn them in HD on my blueray. If I convert them to HD MPEG4 PAL compatible, the Blue ray does not read them. I guess they are not AVCHD format compatible for Panasonic. I have read about MultiAVCHD software ... maybe I should use this to convert back the PAL MPEG4 to Panasonic AVCHD? Is there an easier way of doing it?
Panasonic Lumix GH2 for video
By glenpinn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2012, 02:01 -
Rebuild JPEG Motion Video for play in Panasonic Lumix Camera
By RL in forum ffmpegX general discussionReplies: 0Last Post: 16th Dec 2011, 12:16 -
AVCHD from panasonic lumix, which software is compatible?
By rocketman778 in forum EditingReplies: 0Last Post: 25th Nov 2011, 16:53 -
Converting PAL video to NTSC through SUPER
By DJL82 in forum Video ConversionReplies: 14Last Post: 3rd Jan 2008, 05:23 -
Converting PAL ISO to NTSC for DVD-Video
By Nate7410 in forum Authoring (DVD)Replies: 1Last Post: 18th Sep 2007, 15:27
