I just ripped all my DVDs to VOBs... What should I convert them to so that I can stream from my Win7 Media Center to Xbox 360. I tried all weekend and nothing really worked too well.
Thanks in advance![]()
Results 1 to 10 of 10
If you are using the Xbox 360 as a media extender then you could remux your VOBs to .MPG or .DVR-MS.
There's very little difference between the two, except that .DVR-MS will allow full FF/RW seeking, whereas .MPG will only allow a 30 second back or forward skip.
Converting from .VOB to .MPG is quite easy using VOB2MPG. If you want to go from .MPG to .DVR-MS then ToDVRMS will do that.
If you are streaming to the Xbox's video library, then you will have to convert your VOBs to either AVI (XviD/DivX) or MP4, as MPEG 1 or 2 can't be streamed that way. -
Sweet!
FF/RW was my biggest issue cuz the girlfriend always passes out
. Thanks a bunch!!!
I understand your desire to use your Xbox since you've already got it but the Xbox was years ago rendered obsolete as a media player. It's your time to spend converting/remuxing your files but you could always buy a new streaming media player like from Western Digital or some other company and not have to convert anything.
Who decided that the Xbox 360 was "obsolete" as a media player?
The 360 is a fantastic media player, its only drawbacks are that you need Windows 7 to really make use of it, and the lack of MKV support, which can be quickly fixed by using XenonMKV to remux any files to MP4. Since I prefer to buy my movies rather than download them, MKV files are not a problem for me.
I plan to use my 360 as my main media player long into the foreseeable future, since I don't see a good reason to buy anything else yet. -
I think jman98's point was its not an all in one standalone solution. It can't work without a pc for many of the high-end fancy codecs and formats. It is picky in that sense. And it needs to be streamed to for maximum effectiveness.
I would agree for a plug and play option without a computer involved is to get a standalone media player like the wdtv. That way you just plop the files on a harddrive and go.
But there is nothing wrong with the xbox 360 for many needs. As long as you have a computer in the same room or lan connected it is as versatile as anything else on the market. Just not a off the shelf media marvel like the harddrive media players.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
And plop them onto a hard drive with what?
Which ever media player you choose, there almost always has to be a computer involved somewhere.
I own a WDTV HD 1st generation which I managed to get working wirelessly with custom firmware. It took about a week before I went back to using the Xbox 360 extender again. I just missed the much better user interface. -
All right smart guy you know I meant no computer needed DURING PLAYBACKOriginally Posted by mh2360
I have a 1st gen wdtv also. I have finally been using it more regularly now. Saves a lot of discs and time. And with hdmi I don't need to author and burn avhcds from my hdpvr. It is a pretty basic interface I'll grant you that.Originally Posted by mh2360
I wonder how the screens look on the newest LIVE PLUS models. I wonder if they have spruced them up a bit?Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Why do these 2 files not play on an Xbox 360?
By gers1978 in forum Video ConversionReplies: 0Last Post: 5th Oct 2011, 16:45 -
Converting for play in XBox 360 results in incorrect aspect ratio
By Mule52 in forum Video ConversionReplies: 5Last Post: 11th Apr 2011, 21:12 -
Can I play this MP4 file on Xbox 360?
By Algamish in forum Media Center PC / MediaCentersReplies: 7Last Post: 26th Jun 2010, 14:34 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
Need something like an xbox 360 to play mp4 on tv
By avalanche165 in forum Newbie / General discussionsReplies: 9Last Post: 15th May 2008, 17:35
