If I record sound from my computer into my audio editor, and I use Stereo Mix, there's no sound quality loss right? Stereo Mix simply takes a digital copy of sound that is destined for your speakers. Is that about right?
Generally yes but you usually need to specify your recording format preferences for the timeline (e.g. CD quality 44.1 KHz, 16bit stereo PCM or better or worse). The recording quality you set may limit the quality recorded to the disk buffer. After editing, compression is usually applied (e.g. MP3 or AC3).
http://www.kiva.org/about -
No, that's an analog recording, if you ran a jumper from the headphone jack to the line in.
Realtek HD has no Stereo Mix?
By EwanG in forum AudioReplies: 23Last Post: 4th Sep 2010, 08:53 -
stereo loss after converting from wav to ac3
By Driber in forum AudioReplies: 8Last Post: 9th Sep 2009, 02:29 -
Creating a Pseudo 5.1 Mix from Stereo Source Using V.I.
By guns1inger in forum User guidesReplies: 13Last Post: 27th Jul 2009, 17:21 -
Capture stereo sound and quality video from analog camcorder to dvd
By gxwarr in forum Video ConversionReplies: 1Last Post: 6th May 2009, 16:39 -
Blackmagic Intensity OnAir 2.0 stereo-mix recording?
By Martz in forum Capturing and VCRReplies: 0Last Post: 23rd Feb 2009, 03:32
