Check this device out:
http://www.archos.com/us/products/product_jbmm_vm.html
It's yet to be launched but will be available in my country next week. Was hoping to hear if any of you have tested it. I'm particularly intersted if the 352X288 capture can make decent VCDs.
Thanks in advance.
/Onn
that thing looks awesome... also looks expensive...
i wouldnt want it though unless there was any way to transfer the capture to a computer for vcd creation perposes. -
ok, i looked into it more and it looks like you definitly can transfer the video...
and i was also right, pretty expensive. incredibled toy though. -
Actually it essentially is a mobile harddisk w USB 1 connection (default), and options for USB 2 and IEEE 1394. Wanted one essentially for recording MP3s from microphone sources but later found this version with options for SM/CF media transfers (for digicams) and now... MPEG4 VIDEO CAPTURE!
The real attraction of this device is portability and the video capture means I could use it with old analogue cameras. And a 10GB HDD of MPEG4 videos at 352X288 translates to nearly a hundred (?) hours of video. Only thing holding me back is the untested quality of the video capture. Many reviews gave an older version (the Archos Jukebox recorder) tops for MP3 recording and playback quality.
But video.... I'm still waiting for reviews...
Using HD PVR Capture Module, then placing video in Sony Vegas....
By damonj_3 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 6th Sep 2011, 14:02 -
Pioneer DVR-560HX & random problems with CAM module + video adjust menu
By vincent_scot in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th Mar 2009, 12:03 -
Want to get home video pal VHS onto my pc HDD, recomended capture card?
By ha9981 in forum Capturing and VCRReplies: 6Last Post: 26th Mar 2009, 15:34 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38 -
When capturing to hdd, dv or mpeg4?
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 20th Dec 2007, 07:12
