When I use DVD2AVI, and then TMPGEnc, the video and audio are not in sync. The audio is like a 4-5 seconds behind the video. Is there a way to correct this?
Hey Devious,
How are you capturing your videos? Are you using MMC 7.1 ? IF so maybe I can help you. I had this sync problem for some time until I moved to MMC 7.5 (ATI AIW Radeon) and the problem is gone!
Good luck!
Marcos. -
Devious, how are you verifying that the audio/video is out of sync?
Are you playing the .mpg in Windows Media Player (WMP) or
some other MPEG playback software? -
I have had this problem many of times. I found that you should start the DVD2AVI program where there is both audio and video at the same time. ie. right when the movie starts, right when the intro from the studios starts. Sometimes (but not to often) you will have to start it at the beginning of the movie, after all the studio intros. Never start at a blank screen.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Audio - Video out of sync
By Zenoberr in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2011, 20:54 -
looking so sync audio and video
By loldmanjenkins in forum Video ConversionReplies: 1Last Post: 11th Dec 2010, 22:07
