I've got multiple computers plugged into a KVM switch for mouse, keyboard, and video (VGA). I want to get an HDMI monitor and plug in the one computer that has hdmi, but I want to still be able to switch between computers easily. Is there any way I can do this with little or no hassle?
I use a KVM switch with two of my PCs. They both have HDMI output and VGA output. I also have HDMI output from three DVD players and a WD Live box. The HDMI from the PCs and the DVD players and the WD goes through a remote controlled five selection HDMI switch. Then that output goes to a HDMI splitter. That feeds my LCD monitor, which has HDMI and VGA inputs, and also feeds my HDMI video projector at the same time. Since I use coaxial audio, I also have a 5 input switcher for that. Sounds a bit complicated, but works great.
I can view HDMI from either computer or my DVD players on my LCD monitor, or on my HDMI projector screen.
At least with my computers, they can output HDMI and VGA at the same time. HDMI and DVI at the same time can be a problem with most video cards, though. Usually you can only have one digital and one analog output from a video card.
I use HDMI and coaxial switchers from MonoPrice. I also use one of their HDMI powered splitters. They are inexpensive and work well for me. http://www.monoprice.com/home/index.asp -
If the new HDMI monitor also has VGA plugs, and will switch automatically between inputs, as most of them do, just plug it in and continue as normal.
Win 7 Pro install on multiple computers
By videobread in forum ComputerReplies: 1Last Post: 11th Nov 2011, 14:33 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
I can't get DVDs to play on multiple computers - help!
By RobertUSM in forum Authoring (DVD)Replies: 6Last Post: 11th May 2009, 14:32 -
Use Multiple Computers
By ZoNE97 in forum Video ConversionReplies: 8Last Post: 13th Apr 2009, 15:46 -
multiple webcam recordings on 1 or 2 computers? is it possible?
By MEANGUNS in forum Newbie / General discussionsReplies: 0Last Post: 17th Jul 2008, 15:03
