    Feb 2011
    Australia
    Hi
    Is they any software that can fix voice sync problems.
    Have a movie that has be copied from HDTV. Problem is that halfway through the movie the voices go out of sync. Is there any way to fix this?
    Thanks for any advice.
    Apr 2004
    Miskatonic U
    If it happens at a certain point then it can be trickier to fix. You will have to split the file at the point the problem occurs, fix the part that is broken, then join the two parts together again. How and with which tool depends on what sort of video it is. Post a mediainfo tree/text view and I can offer more details on how.
    Read my blog here.
    Feb 2011
    Australia
    Hi, Thanks for your kind offer to help. This is the media info.
    General
    Unique ID : 226859604871919118467659503877711656537 (0xAAAB92141E13E0B9AC409DDA9F2AF659)
    Format : Matroska
    File size : 1.26 GiB
    Duration : 1h 24mn
    Overall bit rate : 2 132 Kbps
    Encoded date : UTC 2011-04-25 00:03:46
    Writing application : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
    Writing library : libebml v0.8.0 + libmatroska v0.9.0
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 24mn
    Bit rate : 1 715 Kbps
    Width : 1 008 pixels
    Height : 560 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.127
    Stream size : 1.01 GiB (80%)
    Writing library : x264 core 114 r1913 5fd3dce
    Encoding settings : cabac=1 / ref=1 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=hex / subme=4 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=0 / me_range=8 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=24 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1715 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:1.00
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Duration : 1h 24mn
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 232 MiB (18%)
    Apr 2004
    Miskatonic U
    If it were me, I would load the file into AVI Demux, and with audio and video in Copy mode, split the file into two parts at the point the audio breaks. In AVI Demux that means loading the file, setting an in point at the frame before the break and an out point at the end of the file, hitting delete, then saving the result as Part1.mkv. Load the file again, set the in point at the start of the file, and the out point at one frame before the break, and again hit delete. Save this as Part2.mkv
    Part 2 should be the out of sync part. Tick the box marked Shift, and change the shift amount until the audio plays in sync (note : you can use negative numbers to make the audio start sooner than the video). Once you have the audio in sync, save this as Part2fixed.mkv
    You can then load part 1, append part 2 fixed, then save a new file that will hopefully be in sync all the say through.
    This will only work if the audio is out of sync by a constant amount all the way through.
    Personally though, I would just re-rip it and start again.
    Read my blog here.
    Feb 2011
    Australia
    Hi Thanks for the advice.
    Anyways, thanks for taking the time to respond.
