is there a way to remove or cover the "bug" in a video(the image that's in the lower right hand corner of the video)
Search the forum for the terms "delogo" or "delogo filter". I haven't tried it, myself, so I can't comment on how well it works; it will attempt to mask (remove by approximating/blurring the surrounding details) the 'bug'/logo, but reportedly, depending upon factors like the quality of your video, the size of the logo, what it's obscuring, etc., the resulting effect could even be more noticable than the original logo.
But as I mentioned, I'm not the best person to ask about it.
If cameras add ten pounds, why would people want to eat them? -
If its a static logo (no movement) you could get passable coverage over it. If its a moving logo its virtually worthless to remove it. At least that was my experience when I tried removing logos a few years back.
It leaves a watery afterimage. Forget any notion you have of perfectly removing the logo and having a clean image behind it.
At best it will obscure it and you won't read it crystal clear. However the amount of work you have to put into it is simply not worth it in my opinion.
You're welcome to try it for yourself. But basically its not a miracle worker so don't expect a perfectly restored video afterwards.
You've been warned
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
HuffmanFamilyof4-in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time.
https://forum.videohelp.com/threads/221665-Removing-Logos-using-DeLogo-vdub-filter?p=1284286
https://forum.videohelp.com/threads/273109-Remove-an-opaque-logo-using-Xlogo-in-Avisynth
And keep in mind that a blob that looks ok in a still frame may be very distracting when it's in motion in a video. -
It just creates a messy blob that's more distracting.
How to remove annoying "Press Esc to ..." message in Flash Video
By roma_turok in forum User guidesReplies: 517Last Post: 23rd Oct 2017, 10:09 -
Remove green/purple "bloom" from video
By mikeveli20 in forum RestorationReplies: 4Last Post: 3rd Oct 2011, 15:08 -
DeVeDe 3.16.9 build 2 Mencoder "bug" error under XP64
By mail2tom in forum Video ConversionReplies: 1Last Post: 19th Aug 2010, 19:35 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
TMPGEnc DVD Author 3 DivX "Smart Rendering" Bug?
By ln108 in forum Authoring (DVD)Replies: 7Last Post: 23rd Aug 2007, 11:27
