Hi
I'm trying mkvmerge for the first, extracting audio, subs etc and converting them correctly, that I'm aware of
So far everything seems to work when I mux except for one thing I can only play the extracted files within the same folder
Example
original film with Japanese Audio
extracted an English Audio and ASS subtile files and attachments for font etc
setting defaults and yes where needed
I mux and it will register and play these extra files, but as soon as I delete, move etc one of he extraction files when I play the file again it wont register that file.
So i may as well just get my media player just load those files for me.
So is MKVmerge ment to merge this files into 1 MKV so i shouldnt need to use external files or am I doing something wrong, or using the wrong software.
cheers be great to know soon as me being silly, my folders are cluttered, thinking it should be done by now
update- oh yeah I'm perfectly happy with the timing size and font I just want to merge all these files so that I don't have to rely on a second file to play my subs or other audio
You don't specify what you are using to play the video. If it's a software player on the PC then many players will recognize a text subtitle stream in an .mkv if it's .srt subs. DVD players and set top boxes vary with the manufacturer.
If need be you can convert .ass subs to .srt using SAConv
http://sourceforge.net/projects/saconv/
Hard to make additional suggestions without more info.
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
Hi
Im mainly play from pc so pc programs like VLC and Windows Media player Classic
I'm trying to have just the 1 file rather then having a pile of files to play from.
I'll give SRT a try but the thing that confuses me then is the files that I extract the subs from theyre ASS/SSA as well so surely I shouldnt need to change and be able to put an ASS like how the original file did, but I will give it a go anyways
What do people need to know so they can help me then
Update- SRT didnt work I saved/mux the file to a different location and the subs didnt show unless i dragged it into the same folder/location. So Am I using it wrong or something isnt a simple case of select video that comes with a original audio annd then select the sub file and I add atachment for style text etc and hit muxLast edited by call4jim; 25th Apr 2011 at 06:13.
Ok after some playing about, the combined file plays on vlc, jus not windows media player clasic but it recognise that here is a sub file just cant see it same with the ffds and haati thy know theres a sub file. so is something wrong with windows media player classic
using mkvmerge gui
By zoloabc in forum EditingReplies: 8Last Post: 26th Jun 2014, 12:44 -
Question about using "delay" in mkvmerge.
By Gothic Autumn in forum AudioReplies: 0Last Post: 13th Jun 2011, 21:30 -
Need Help with MKVMerge 4.2.0
By muramasa007 in forum Newbie / General discussionsReplies: 5Last Post: 31st Aug 2010, 19:46 -
Error -1 with MKVMerge
By cedworld in forum Video ConversionReplies: 4Last Post: 28th Mar 2009, 12:06 -
Is it ok to use MKVMerge twice on the same file?
By NextJinGamer in forum SubtitleReplies: 3Last Post: 22nd Aug 2008, 18:36
