I'm trying to convert a DivX movie to SVCD, and want to keep it's original framerate of 23,976 FPS to avoid studder. But when I use the NTSC film template in TMPGEnc, which is supposed to use 23,976 FPS for the encoding, the converted file has a framerate of 29 as if it used the NTSC template. Is this a bug in TMPGEnc, or am I missing something? Thanks in advance.
I cant claim to be familiar with this template but what you may be seeing is the effect of 3:2 pulldown applied by Tmpgenc. What are you using to inform you of the framerate of the output file? Tmpgenc can insert the 3:2 pulldown flags in order to allow a NTSCFilm Mpeg to be played back at normal NTSC frame rates, perhaps this is being interpreted as 29 fps. Check the 3:2 pulldown setting in the advanced settings tab of Tmpgenc after loading the template, you may want to clear it.
BTW, I have found (doing DVD encoding) that TmpGenc produces slightly jerky video when using the 3:2 pulldown setting, but using the standalone pulldown.exe produces much smoother results. I cant claim to know enough about this topic to explain how this could be!
Using NTSC (16:9) and PAL (4:3) sources to restore a film...
By takearushfan in forum RestorationReplies: 61Last Post: 3rd Mar 2012, 15:13 -
Converting a Final Cut Pro Motion template to a DVD Menu...
By Huntr777 in forum MacReplies: 0Last Post: 4th Apr 2010, 12:48 -
NTSC/PAL but exact film length: How so?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2010, 11:42 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
Question regarding NTSC Film DVD
By txporter in forum Video ConversionReplies: 14Last Post: 30th Nov 2009, 09:29
