Hi, I've got a 155 minute AVI file that I want to turn into a DVD player playable DVD. ConvertXtoDVD version 3 turns it into a 95 minute file with the video played too fast, whilst the audio remains normal speed. As far as rthe log was concerned there were no errors. This hasn't happened to any AVI file I've tried to convert before. AVIdemux and VideoDubMod both cannot load the AVi file although Media Player classic has no problems playing it. I don't care one whit about video quality, I just want a DVD that my Dad's standard DVD plyer will play. Can you suggest what is wrong, a potential fix or a simple fast and free converter that will not have this problem.
File type: ogg media
Mime type: application/x-ogg
Now, can someone please answer my question? -
That can't be all that's in the AVI... what are you using to get information on the video? Run it through MediaInfo, in Tree Mode; copy the information it gives you and paste it here.
There's also GSpot, of which you can post a screenshot of the output window. However, GSpot doesn't support video containers other than AVI and MPEG as well - and as you mentioned Ogg Media, that makes me wonder if your AVI isn't a renamed .OGM video. I'd certainly prefer to see more information before jumping to that conclusion, though.If cameras add ten pounds, why would people want to eat them? -
So, I did what the first guy asked. I downloaded a program and told you what it said. So nobody is willing to hhave even a guess what is happening?
The file is faulty - corrupt data, bad index, something. Post a full tree view of the file details from mediainfo so we can see what it thinks of the file. Playback is easier than encoding. Many several players are robust enough to get past minor and even major issues with a file and still play it back. Encoding, on the other hand, required the file contain good data, and no errors. if you have a player that can play the file, you might be able to do a screen capture of the playback and encode your DVD from that. Otherwise, you8 will have to either fix the file, or get a better source.
Read my blog here.
VSO Blu-ray to DVD
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2011, 12:40 -
Slower encoding with VSO than it used to be
By Brainstorming in forum Video ConversionReplies: 8Last Post: 28th Dec 2010, 20:52 -
pc crashes with vso convertx
By dvdex in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2009, 18:40 -
Circuit City to shut 155 stores to preserve cash
By MJA in forum Off topicReplies: 11Last Post: 5th Nov 2008, 22:09 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 02:19
