hi
anyone use soft which will allow me to demux from IFO source pgc main movie title to 1 single vob please?
pgcdemux cant make 1 big vob and splits it to 1gb each. i need just 1 single big vob.
thanks for help![]()
Not sure what you mean by IFO source pgc main movie title... but if you have the complete, decrypted VIDEO_TS folder just use VOB2MPEG. DVDDecrypter can also rip stuff as one, giant lump of video as long as the disc is not brand new with new encryption techniques.
hi
will explain
movie already ripped on HDD in IFO and VOB files.
so i need to somehow load IFO and get 1 single vob (for example 4GB)
pgc demux can load ifo movie but splits vobs to 1gb each if i select pgc which is bigger than 1gb it splits it.
if this program could demux to 1 single vob it would be what i need but does not do it
(dont forget sometimes there is episodic dvd with more pgc titles) -
You don't want your final product to be a VOB file....you want it to be an mpeg file. VOB files are for DVDs and are either useless or troublesome under most circumstances outside of the DVD file structure.
You could even open the ripped DVD in DVDShrink and take what you want that way....at least you will have a preview to look at....then convert that to mpeg with VOB2MPEG. -
This begs the question, 'why'? Why do you need the movie or episode in a single VOB? Is it for editing, or for some other reason?
yes i need 1 big vob for editing to load it to some program as this program cant load 4 vobs
Then you do as hech54 suggested and use VOB2MPEG on it Either that or make an ISO of it, mount it, and use DVDDecrypter on the ISO to create a single VOB file. VOB2MPEG is the much better choice.
Need to make IFO, BUP for Single VOB
By Simmons in forum Authoring (DVD)Replies: 5Last Post: 28th Aug 2011, 20:15 -
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 19:49 -
How do I convert VIDEO_TS containing VOB, BUP, IFO files to a single file
By Firesmith in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2010, 11:14 -
DVD main title to single file, with AC3/DTS
By knight76 in forum DVD RippingReplies: 5Last Post: 27th Feb 2009, 10:30 -
Need to demux from PGC?
By videopoo in forum Authoring (DVD)Replies: 0Last Post: 11th Jul 2007, 15:50
