I am a bit confused on how to use the software to correct the audio/video sync. Anyone have any good information they wanna share? Also, whenever i try to load in the .avi file when clicking on the "sync audio" tab, it says "that the pins are not connected". Please help!
thanks
that tool died about 8 years ago. probably not going to work with current "avi" files.
avidemux might work. open your video. leave video and audio on copy. make sure format is set to avi. under the audio configure and filters options is a check box for shift. but a check mark in the box and you can shift the audio foeward or back to try and sync them up. then save video to write your new file.
TTempsmooth Help Needed
By VideoFanatic in forum RestorationReplies: 43Last Post: 4th Dec 2011, 23:15 -
AviSynth much needed help!
By dbanimal in forum EditingReplies: 18Last Post: 28th Jan 2011, 10:33 -
HELP!! New Camera Needed
By hhouser in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2010, 05:05 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
