Is it possible to convert any video/audio file to real media rm/rmvb using ffmpeg.
I found this stuff - go to 4. Tips http://www.ffmpeg.org/ffmpeg-doc.html
- ffmpeg -g 3 -r 3 -t 10 -b 50k -s qcif -f rv10 /tmp/b.rm
This command dosn't work for me![]()
The example from ffmpeg.org isn't very helpful. You need to specify an input video with the '-i' option. Also, with the example you posted, ffmpeg says ''rv10' 'isn't a suitable output format'.
Why do you particularly want to encode to Real Media? Have you considered .mp4 (h264/avc)?
What frame rate, resolution and bitrate do you want the video to be?
This seems to work:
ffmpeg -i input.mp4 -g 3 -r 10 -qscale 8 -s qcif -ac 1 -vcodec rv10 -acodec real_144 -f rm output.rm
(although I haven't got RealPlayer on my computer, so I can't see if it produces fully compliant video)
*replace 'input.mp4' with the name of the file want to convert and change 'output.rm' to whatever you want, as long as it ends with .rm
ffmpeg should output a file that is:
- 10fps
- ~200kbit/s
- 176x144 pixels
- 1 channel audio (mono) 22.05KHz -
1/ This forum is not for ffmpeg, but for ffmpegX, the Mac GUI front end to ffmpeg, mencoder and mpeg2enc.
2/ The command line you provided is an example tip for streaming at very low bitrate application, illustrating the use of a low frame rate (-r 3) and a small GOP size (-g 3). It also writes to the tmp directory. And it doesn't specify an input.
3/ My copy of command line ffmpeg (0.6.1) can DECODE Real Media (upto RealVideo 4.0/RealAudio 2.0), but only ENCODE to RealVideo 1.0 and RealVideo 2.0 (video only).
See ffmpeg -formats and ffmpeg -codecs to see supported formats and supported codecs for your version. Make note of the letters 'D' and 'E' for decoding ability and encoding ability.
4/ Are people still using RealMedia?
ffmpeg to windows media server - what does the code look like?
By cyberskoglund in forum Video Streaming DownloadingReplies: 0Last Post: 1st Oct 2010, 15:50 -
Real time test of media - whether I like it or not
By arcorob in forum MediaReplies: 12Last Post: 18th Feb 2010, 21:55 -
Converting Real Media
By KLouis22 in forum Video ConversionReplies: 2Last Post: 29th May 2009, 17:47 -
real media to avi help
By odiedog in forum Video ConversionReplies: 5Last Post: 18th Jan 2009, 06:10 -
Real media Bitrate calculator?
By ViB in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2007, 14:34
