I just purchased a new BD player. The S580 from Sony. I noticed the Sony works the FF and RW functions different than my old LG. When watching a show/movie etc, my LG would show a slidshow of the movie as you moved foward or in rewind. The slideshow was limited but helped in finding the area you wanted to get to. My Sony only shows the time movment while the scene from where you were is static. Is this how they are doing it now?
Results 1 to 10 of 10
Don't give in to DVD2ONE, that leads to the dark side.
Are you referring to netflix itself?
Or are you referring to bluray disc playback? It might be dependent on the movie itself. I think different movies show fast forwarding differently - I don't know that for a fact however, never really paid attention to be honest.
Have you checked the players menu system? Perhaps you can enable it or disable whatever features the player has?Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I'm refering the the Nexflix feature. Thanks. Yeah, I don't see a setting in the menu system to ajust the Netflix feature. Which way does yours work?
Don't give in to DVD2ONE, that leads to the dark side. -
I don't have netflix anymore. When I did I used my ps3 or xbox 360 to watch it. I don't remember seeing a little preview window during fast forward or reverse. Doesn't mean it wasn't there just that I don't recall. And a console might be setup differently from a settop player anyway.
I see it when streaming videos from netflix to my pc through my browser, but i setup a Wii recently to watch netflix through and i do not see the preview thumbnails below the main window so it might just be something that shows up through web browsers ?
But if your standalone LG player showed them then maybe it's something that only certain players are set up to show. -
The feature was useful when FF through the credits to start shows.
When i use ff and rw while streaming netflix with my PS3, thumbnails appear.
I just finished watching some episodes of Sliders that way, and that's how it worked.
Normally, if need to ff or rw, i just pause it, then use the arrow keys to go through the thumbnails. -
Originally Posted by marco33
It has regular firmware updates. To suggest it is just like it was when it launched is not correct. Yes the hardware chipsets are fixed back to the launch date but how it does things and what it can do software side are always evolving.
Don't forget the ps3 did not launch with netflix support. That was added on laterDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Sorry let's get away from the PS3. I guess what I realy want to know is; is the way my new player handels Netflix (ff function) now the "standard". So instead of thumbnail FF, which is the way my old player handeled it and like the PS3 does, it just shows the time moving foward with no visable indication of movment. Basicaly you have to guess where you are by the time code.
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 18:25 -
URGENT: Any Blu-Ray players with adjustable audio delay / lip sync feature?
By psychotronicfilms in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th Feb 2011, 19:45 -
Name of feature that allows DVD/Blu-Ray players to remember spot when off
By Dreadnaught in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Feb 2010, 18:14 -
Netflix To Raise Prices On Blu-ray
By MOVIEGEEK in forum Latest Video NewsReplies: 1Last Post: 31st Mar 2009, 05:38 -
Netflix to hike up monthly Blu-ray fee by up to $8
By MJA in forum Off topicReplies: 2Last Post: 30th Mar 2009, 23:44
