Hey,
I'm trying to burn a project to Blu-ray in Adobe Encore CS4. It's rendered out from Premiere Pro CS4 to 2 seperat files for sound and video.
No matter if I render to H264 or Mpeg2, Encore (and the pc) crashes, when I try to import them to the program.
The only option I have is to hardware-reset the machine to move on.
I have reinstalled Encore a few times and I have the newest update for the program.
Is this a known issue and does anyone know how to solve it?
- Import of dvd files works perfectly..
Kent.
Don't know the answer to your question but have you tried to Adobe Dynamic Link? If not, see if that works.
Brainiac -
This will fix your problem... http://kb.roxio.com/search.aspx?URL=/content/kb/GeneralInformation/000070GN&PARAMS=
I didn't believe it, but it works. -
If DVD MPEG2 files import properly then it would seem encore is okay.
The next thing I will do is verify if the files premiere are producing are not corrupt, are blu-ray compliant, and are playable (by testing with vlc, for example). Use MediaInfo to post file details here. I always try to put premiere and encore project files in a separate drive from the system drive. I also start them in the administrator mode (not doing so may or may not prevent access to some unique codec required). I have never used adobe media encoder (ame) to export files from premiere because of quality and other issues, using x264 for MPEG4 and CCe basic and HCenc for MPEG2 instead. To use these, you should install a frameserver (such as debugmode frameserver) in premiere, which creates a signpost *.avi in export, which you then include in an avisynth script to use as input (of course you have to install avisynth first as well).
Even if you use the blu-ray template with ame, you don't know if open GOPs are enabled or not. Encore is known to either be very slow or crash if presented with open GOP files when importing. When using x264 (with an appropriate GUI, such as simple x264 launcher), you can include the arguments taken from http://www.x264bluray.com/ to produce blu-ray compliant files. Note that in the samples given, the argument --open-gop is present (enabled), so merely deleting it to create close GOP files can make encore happy.For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
Problem with Encore and Blu-Ray
By kimco52 in forum Authoring (Blu-ray)Replies: 6Last Post: 28th Nov 2011, 20:26 -
Authoring Blu Ray in Encore
By Vasilis in forum Authoring (Blu-ray)Replies: 6Last Post: 19th Nov 2011, 13:44 -
Ripping Blu-Ray for my own Encore projects
By koberulz in forum Blu-ray RippingReplies: 2Last Post: 11th Aug 2011, 11:50 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 07:51 -
CS4 Blu-ray Question
By jbandy1 in forum Authoring (Blu-ray)Replies: 0Last Post: 4th Sep 2009, 04:18
