MKV is not an editable format, and most editors are not going to load and work with MKV files. You could try using something like AVI Demux or Xmedia Recode to re-package the contents (audio and video) into an MP4 or M2TS container and trying loading those instead. Use the Copy mode in either tool to avoid re-encoding, and the process should only take a couple of minutes. If you choose Xmedia Recode then I would recommend going back a couple of versions to find one that re-packages AC3 into an MP4 container properly. This one is the one that works for me. Be aware that most mkv files are already heavily compressed, and after editing with Vegas you will have to re-encode them yet again.
Read my blog here.
You don't have to demux you can use DGIndexNv GPU version (not free) it use the graphic card to decode AVC (Nvidia cards mainly i think) in .ts .m2ts, mkv (etc...). Problem is i have it installed but it don't work with my own made mkv's .I have tried with another one (movie downloaded on the net and it work, 100% sure)
After that you make an avisynth script and import it in SonyVegas by doing a pseudo .avi (very small) with AVS2Avi, google all that.
The script goes like this:
DGMultiSource("C:\MyVideo.dgi",i420=true,deinterla ce=0,use_top_field=true,use_pf=false)
Check the manual for more details*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
Do all Sony & Panasonic Bluray players recognize AVCHD files?
By jbitakis in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Nov 2011, 04:19 -
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
SFL files in Sony Vegas 8.0
By scathefired2e in forum EditingReplies: 1Last Post: 3rd Dec 2007, 02:29 -
AVI files in SONY VEGAS
By thompskm in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2007, 06:44
