Have been converting avi files with hardsubs (.srt) to DVD (TS Folders) for years with ffmegX on a Mac running OSX 10.58. This past week, the process has started taking over 18 hours, when it usually takes less than an hour to convert. The resulting TS folder plays with subs and audio, but the video is only a white screen, no picture.
The only thing I can think of that I did over this period of time was to update Perian for Quicktime, so I uninstalled that; but got the same result. Browsed through this forum and found something about Perian encoding the subs, so changed the setting on ffmegX (OPTIONS>mpeg2enc options). Tried with "Decode with Quicktime" off, then with "Decode with mplayer" off, and found I could get Xvid Mencoder to work (my fall back when all else fails--even though the subs are small).
I am still waiting on a avi to DVD file to burn from last night (18 hours ago) and it's at 97% now. When it's done, I will post the Log, but wanted to post this in case there's a quick, easy answer that I didn't read. Thank you in advance for your time.
Deselecting the "Load external Subtitles" box in the Perian pref.Pane seems to have fixed the problem!
Editing video in virtualdub taking so long!
By admirer in forum Newbie / General discussionsReplies: 14Last Post: 8th Apr 2010, 13:43 -
MPG Files taking a long time to open.
By Ads79 in forum Software PlayingReplies: 8Last Post: 13th Nov 2009, 09:39 -
Rendering taking too long- How to speed it up? (Sony Vegus movie)
By Entry in forum Newbie / General discussionsReplies: 9Last Post: 18th Aug 2009, 00:47 -
Settings Correct? Taking a Long Time/.avi to DVD
By 5Buffalo in forum ffmpegX general discussionReplies: 3Last Post: 24th Dec 2008, 14:29 -
Making DVD video taking very long time. For advice.
By seymoria in forum Authoring (DVD)Replies: 4Last Post: 11th Mar 2008, 02:59
