Avidemux 2.5 video is out of sync an same with flvjoin videos are flv4 mp3 audio
FLV is a bastard, dead-end file format. Once something is in FLV even the best of programs choke on it. Find another source.
There are different types of flv. The popular one nowadays is h264/aac in an flv container. It is no different than an mp4 or mkv except for the container.
You could try flvjoin to join flv files.
You could also try flvextract (it gives the framerate of the file) and put the streams into an mkv or mp4 container.
The new versions of Virtualdub will open flv with fcchandler's flv plugin and aacacm. If the audio is nellymoser then you'll have a very hard time trying to work with these files. Nellymoser is a proprietary format and I don't know of any software that will convert it to something usable. -
I've only just found out that there's more than one FLV, when VLC told me it only handles FLV* (have forgotten what the number was)
The recordings play fine in VLC, but I was trying out VLC to convert, just for the sake of it, having read about it whilst browsing the forum. Also today, AvideMux wouldn't handle my recordings.
How do I find out which FLV my recordings are, please? They're screen-captures done by Debut.
(I choose to record in FLV because everything else takes so long to upload to YouTube, and the original quality is nothing to write home about, it's the subject matter that's important.)
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
Using mencoder to join mpeg video result in a/v out of sync.
By Jemore in forum EditingReplies: 3Last Post: 18th Jan 2012, 02:02 -
flv Audio/Video out of sync
By anmldr in forum Newbie / General discussionsReplies: 2Last Post: 24th Jul 2010, 11:30 -
.mov to .flv - Sync issue and shortened video.
By dillingham in forum ffmpegX general discussionReplies: 1Last Post: 4th Jun 2008, 16:15 -
FLV Video Longer Than Audio... How to Re-sync ?
By Babalou in forum Video ConversionReplies: 9Last Post: 16th Apr 2008, 12:43
