  1. Hi there, I'm currently using SupRip to covert SUP subs to SRT format. Problem is, I have accidentally entered the wrong letters in a few times an now it keeps putting in the wrong letter. For example, I typed "r" instead of "t" and now i keep getting "the" as "rhe". I have tried deleting SupRip and its folder and also cleaning the registry (probably wouldn't have been needed) but it still remembers the incorrectly entered letters. Is there a way that i can get it to forget them? Thanks
    Jun 2004
    California,United States
    SupRip has a temp file. I have Win XP and for me it is located in the Documents and settings folder. It would be in one of the secondary folders in that folder. Could be as Administrator or users etc.
    It would than be in it's Application sub folder and it's sub folder SupRip. It would have the name temp.font.txt
    Hope this helps
    Tony
  3. Thank you for your reply. The file was in a different location in Win7 but i managed to locate and delete it. Thanks very much for your help!
