ok....after searching endless numbers of forums trying to find ways to improve my capture quality and a way to increase my capture resolution i stumbled upon an update from microsoft. it may not be new to you guys, but to me it was new and a God sent. Now I can capture at whatever resolution I want with no dropped frames, where as before I dropped frames at 352 x 240. here is the link.....its well worth the small download.
http://www.microsoft.com/windows/directx/downloads/vidcap.asp
this thing even cleared up the sound problems i was having...i dont know how but it did![]()
enjoy!
system:
1ghz athlon
studio pctv pro
30 gig ata100 7200rpm capture drive
30 gig ata100 7200rpm system drive
gefore2 ultra
tbsc sound card
384mb pc-133 ram
monsoon,
This update for directx8.0 has been out for a while, however you may not be aware that the latest release is directx8.1 and it incorporates the patch.
One other thing to keep in mind is that if you're running Win98SE and you have to re-install windows, even over your current installation in order to keep your desktop settings etc, just check the version of directx. Chances are that it will be back at vers 6.1 and it will require updating.
All the best,
Ronin2 -
Hey you, moonsoon01, thanks for finding VidCap. I was trying to find it on Microsoft's Web-site. Very convenient of you. I should have looked at your note a few hours ago.
By the way, just a note that this video capturing update doesn't apply to OS WinXP.
Thank you and I have installed this patch into my computer that runs Windows Me.
REGARDS CHRIS
every1, first off, i'd like to say sorry for the late response...i was on vacation. ok, ronin2, i have directx 8.1, but i still dropped frames like crazy, but as soon as i installed the video capture thing it stopped...so it was a quick fix for me. hopes this helps everyone.
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 12:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
HDVSplit dropping frames
By Boadicea7 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2009, 09:47 -
DivX Dropping Frames? But Why?
By Anakin in forum Video ConversionReplies: 5Last Post: 12th Apr 2009, 02:25 -
New Computer Dropping Frames
By bthig in forum Capturing and VCRReplies: 20Last Post: 14th Jul 2008, 16:06
