I am new to the whole HD thing. I recently got a Canon Rebel T2i DSLR camera and it has HD video. So at 1080x1920 I recorded some video. I put it on the computer and then (since I don't have a bluray player yet) I burned this video to a regular dvd. The best quality being 720x480. So when I played it back on my HDTV, needless to say I was disappointed in the quality. So at the risk of sounding dumb, does a bluray player allow me to play bluray disks and these bluray disks will they play my HD movie at 1080x1920?
The next question is how do I get this HD movie onto the bluray disk? Do I also need a bluray recorder? Do they sell both as one (bluray player and recorder)? Do I first put this HD movie onto my PC and then burn it to bluray?
Sorry for the dumb questions, but after seeing HD quality on my TV, I want that same HD quality for my home movies.
James
You need a bluray burner in your PC, or a bluray recorder if you want to burn your efforts to bluray disc. If your player supports AVCHD then you could look at using Multi-AVCHD to author HD onto standard DVD blanks. You can fit around 40 minutes of 1080p footage at decent quality on a standard disc. Burn the results with Imgburn.
Read my blog here.
When you say "if your player supports AVCHD then you could look at using Multi-AVCHD to author HD onto standard DVD blanks".
By, "player", do you mean the blueray player? Do I still use my pc somehow? Can't I put more HD stuff on an actual bluray disk vs. trying to use Mulit-AVCHD to author the HD onto a standard DVD? But how much more $$ are bluray disks vs. Standard DVD disks?
James -
Ok, can I buy something like this to make HD home movies on blu-ray? http://www.amazon.com/External-Blu-ray-Rewriteable-laptops-notebooks/dp/B003VGHD0A
Or do I need something else?
James -
Ok, I see that an external blu-ray burner is BIG $$, so are you saying that if I buy a blu-ray PLAYER that supports AVCHD, then using Multi-AVCHD I can author HD video on standard DVD. This seems like a MUCH cheaper way to go right now until Blu-Ray Burners get cheaper, correct?
James
Best Way To Put A Camera Recording Online?
By PHNeedsHelp in forum EditingReplies: 1Last Post: 17th Feb 2012, 03:29 -
Put back my HD Files and playback again from camera
By mavelgr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 19th Jul 2011, 16:37 -
How to put 15hours+ SD video into one 25GB Bluray disc
By kmnorya in forum Authoring (Blu-ray)Replies: 3Last Post: 5th Sep 2010, 06:04 -
SD Video Camera Vs. HD Movie Mode on Digital Still Camera.
By CP/M User in forum Newbie / General discussionsReplies: 20Last Post: 20th Nov 2009, 15:57 -
If I put my wedding movies from dvd to bluray, will the player upconvert it
By bnbhoha in forum Blu-ray RippingReplies: 10Last Post: 22nd Apr 2009, 00:35
