Hello -- I'm interested in simply editing/cutting the start and end points of a Blu-ray title. Both Nero Recode and DVD Shrink have been great at doing this for DVDs -- but it seems like they don't work for Blu-rays....
Is there a prog for BR that can quickly "analyze" a title and allow me to edit -- instead of first ripping the entire disc to my HD?
Thanks for the help.
Results 1 to 9 of 9
No reply yet, huh?
I'm not aware of any all-in-one that can cut and remap, then output a new BD structure. Certainly not any freeware. Lots of ways to do it manually, and you can even re-insert an edited title back into a full structure (with non-java menus) using multiAVCHD or BDEdit.
I've done a few, movie-only, extracting main movie with Clown_BD (to join the *.m2ts files primarily, if there are more than one). Then open the *.m2ts file in tsSniper, cut out whatever isn't wanted, and output a new *.ts file. Then author to Blu-Ray with tsMuxer, manually entering new chapter marks or just setting one every 5 minutes or whatever.
But something along the lines of DVDShrink or Recode? I don't think so.Pull! Bang! Darn! -
fritzi93, redwudz -- thanks for your replies!
damn, i thought that editing BRs would be as simple as DVDs. didn't think they would be so different from each other...
so which easy programs (free or pay) can I use to just extract a scene from a BR movie?
thanks again for the help.
Several ways to extract the BD files. I rip the entire BD to my hard drive using AnyDVD HD. Then I use tsMuxeRGUI to extract the main movie and audio. It can trim the start or ends of a file, though I haven't tried that. If you wanted to do more complex editing, then you need an editor that can handle .ts streams from tsMuxeR. Try TSSniper or maybe AVIDemux.
A problem with any highly compressed format like the H.264 that is used with Blu-rays is that frame accurate editing is very difficult. Mostly you can only cut on keyframes (I frames) and they are widely spaced with highly compressed video. For example Xvid/Divx uses about a 300 frames keyframe spacing. That's what makes accurate editing difficult. Those formats weren't designed for editing, just high compression and space saving.
The second problem is dealing with the huge filesizes. 20 - 30GB files sizes are fairly common.
After you've done your editing, then if you want a Blu-ray that would play on a standard BD player, you would need a Blu-ray burner, BD media and a BD authoring program. Maybe multiAVCHD. Burn to BD disc with ImgBurn.
All the programs I mentioned are freeware, (Except AnyDVD HD, but you can try the freeware DVDfab HD) so the only costs would be the BD burner and the BD media. And there are other ways and other programs that may work better or easier. I leave that to others to suggest.
There's a fairly sharp learning curve to doing all this, so I hope it's worth the effort.
Clown_BD can split by chapter. Other than that, you'll have to do it the hard way. (There are a couple payware h264 editors that claim to be frame-accurate, but I can't vouch for that. Supposedly only the area at the cuts will be re-encoded as necessary.) You can make pretty good cuts using tsSniper with a little practice, but not frame-accurate. It works best when you can cut at a few black frames.
Pull! Bang! Darn! -
redwudz, fritzi93,
thanks again for your posts! i'm going to check out the apps you both mentioned.
appreciate the help!
Hi,
Sorry to resurrect an old thread but you mentioned that ClownBD can split by chapter.
In order to pull out a chapter from a BD do I need to rip the entire movie to hard drive as an ISO/Folder with something like AnyDVD HD, or will ClownBD rip it straight from the BD disc.
The only reason why I ask is that I'm pretty sure that when I have ripped a BD with AnyDVD HD it doesn't keep the chapters but just rips the main movie as one big file.
Please enlighten me as I want to create a demo DVD-9 with various chapters form different BD's as I used to do with DVD's and DVDShrink - that was so easy
Thanks -
AnyDVD HD rips the whole BD, everything, minus the encryption. There are some setting for ignoring trailers or disabling BD Live.
With other programs you can extract just the parts you want. tsMuxeR for one. I use it for extracting extras at times. I don't think it can separate by chapters.
RipBot does just extract and re-encode the main movie.
I don't use ClownBD, so someone else can answer that.
DVD Shrink for Blu-Ray. anything like that out there?
By Bamahusker in forum Newbie / General discussionsReplies: 22Last Post: 9th Feb 2015, 22:39 -
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 4th Jan 2011, 00:35 -
DVD Shrink and Nero Recode question.
By siratfus in forum DVD RippingReplies: 8Last Post: 13th Jan 2010, 22:49 -
Nero Recode vs DVD Shrink
By PhoneMatt in forum DVD RippingReplies: 2Last Post: 8th Feb 2008, 14:04 -
Has anyone switched from dvd shrink to nero recode
By ultraman36 in forum DVD RippingReplies: 3Last Post: 5th Sep 2007, 00:45
