Closed Thread
Results 181 to 210 of 640
It arrived Tuesday. AZ -> Louisville (UPS's sorting facility) -> Seattle -> Bellingham, WA -> Point Roberts, WA.
Tested it with the BlackMagic HyperDeck Shuttle and my cable provider's On Demand service.
Sure enough, it works. Despite the photo on Amazon, it doesn't have any Cvid branding printed onto the top.
Looks like the seller no longer has any stock in Amazon's fulfillment center, as they're now charging for shipping direct from them.Last edited by Brad; 9th Feb 2013 at 19:08.
Oh baby, IT WORKS!!! YAY!
Brought to you in full digital video and sound! (and I apologize for the quality of both, very limited upload bandwidth here
http://rogerslive.click2stream.com
Looks SOOOOO much better than HDMI to Component
That's digital cable box -> hdmi -> 1x4 HDMI Splitter -> hdmi -> Black Magic Intensity Pro
Woot.
-Jamie M.Last edited by toysareforboys; 19th Feb 2013 at 02:25.
There aren't very many because most HDMI sources are HDCP protected so few people can use them. A few of Black Magic's Intensity series, the Avermedia HD series, Japanese "MonsterX" series?. I'm sure there are more but many have been discontinued -- probably because of high returns from customers who didn't realize the device wouldn't record their HDCP protected cable box, satellite box, etc.
i purchased 3 of these units from the ebay seller...shipped right from Chicago. all 3 work perfectly! Can record netflix or VUDU movies straight from any device that supports them...zero lag at all. would HIGHLY recommend this device. 1080P high quality video and sound. absolutely perfect!
I've had awesome luck using this device:
http://www.amazon.com/gp/product/B008ZT8QKO/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
HDMI inputs and the recordings are exactly like the original source. awesome piece of equipment. you can even rent 3d movies on VUDU and record them in 3D! one of my main reasons for purchasing the splitter was so i could rent movies and record them in 1080P at the same time using hardly any CPU resources. this setup lets me do this perfectly and then use Adobe Premiere CS6 to recode down to 720 or whatever i want. using my Nvidia 670 i can re-encode a 2 hour movie in like 30 minutes using GPU acceleration! love it!
"That" does...narrows it down ehh? Thread has been talking about hardware devices that RE-ENCODE the source usually in H.264. like i said previously, awesome piece of equipment is the Hauppauge and this splitter HDCP stripper!! I have three because i thought so much of them!
Simply don't think you've been listening. Not all devices HAVE component outputs. Also, why would i want to use component when I can get the surround sound signal coming via HDMI instead of using an analog signal? For those wanting a clean HDMI to HDMI splitter getting rid of the HDCP, this device is for you. Awesome device!! Love it!
Again, YOU aren't listening. Hauppauge's have component INPUTS. Therefore, you can record in HD. And the audio is captured digitally so you get 5.1.
Yes, it IS an awesome device. However, EVERYTHING is re-encoded: both audio and video. And you DO NOT need a stripper to use it.
Make sense yet?
Serious? I always thought these boxes weren't capable of outputting HD over Component, not that it was a restriction by my cable provider!
If I had have been able to record the component I wouldn't have bothered with all of these HDMI to Component and HDMI decrypter devices
-Jamie M.
Digitalfreaknyc: you are always going to have to re-encode when capturing component or HDMI, because unlike Firewire they are only designed for display purposes, not data transfer. The best you can do for HDMI capture is a 100GB/hour lossless video file that is a mathematically perfect recreation of the decompressed input signal -- if your device outpits 4:2:2.
The Hauppauge does not re-encode AC3 audio, by the way. Somewhere they mention that.
And somewhere among my posts are a few 5.1 + HDMI cards I have found online. The Korean ones seem difficult to acquire, unless you buy from Amazon Japan and pay a middleman.
HDCP
By Baldrick in forum GlossaryReplies: 7Last Post: 4th Apr 2023, 12:34 -
HDCP troubles...
By AKA510 in forum Blu-ray RippingReplies: 7Last Post: 27th Nov 2009, 09:12 -
WD TV is HDCP compliant?
By Supremo316 in forum Media Center PC / MediaCentersReplies: 1Last Post: 20th Nov 2009, 20:29 -
HDCP the way forward.
By NICEBUD in forum Newbie / General discussionsReplies: 5Last Post: 23rd Sep 2008, 17:36 -
HD HTPC and hdcp ?
By bluraid in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 03:52
