Thread: AVI Motion JPEG to x264 in Matroska MKV container
  1. #1
    Member
    Apr 2011
    Belgium
    Posts
    22
    Hello everyone,
    I'll explain my situation. I captured a HD video (720p) with my BlackMagic Intensity Pro. The file is compressed by Motion JPEG, but it is still very big (around 10 GB for 25min). Because I can't store much files of this size, I want to convert it to x264, allowing lower bitrates. First I want to skip the commercials! I read a lot on the internet, about MeGUI. How should I first cut the video (commercials) and convert it to x264?
    Thanks!
    I'm a MEGA Super Moderator Baldrick's Avatar
    Posts
    43,722
    Re: AVI Motion JPEG to x264 in Matroska MKV container
    Try Avidemux, open avi, set start and stop, delete. Save as a new avi. Or compress directly to a mkv h264 with avidemux, under video choose mpeg4 avc and configure compression options, save as a mkv.
    Member
    Apr 2011
    Belgium
    Posts
    22
    I'll try it. Can I skip frames in the middle of the movie ? Because you tell me "start and stop" but the commercials are in the middle of the movie. Thanks for your answer!
    EDIT : I figured it out. Seems to be a nice prog! Thanks!
  1. change an MKV container to AVI container???
    By Spdngblt56 in forum Newbie / General discussions
    Last Post: 17th May 2010, 21:23
  2. Replies: 4
    Last Post: 4th May 2009, 08:22
  3. Replies: 11
    Last Post: 21st Mar 2009, 16:43
  4. GUI to convert Matroska (*.mkv) To AVI
    By qwerty9876543 in forum Linux
    Last Post: 17th Mar 2008, 21:38
  5. Converting or demuxing MKV's to another container using x264 or vc-1
    By dm_0001 in forum Newbie / General discussions
    Last Post: 9th Jan 2008, 14:19
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
