Okay my problem is this. I extract a certain episode off the DVD. I usually re-encode it to make a quick encode. So I can subtitle the individual episode. Sometimes for whatever reason the audio is out of sync. So if that happens. I just use MKVtoolnix to merge the .m2v file and the .ac3 track all together to make a mkv (I extract the .m2v and .ac3 using pgcdemux). And I use that to sync subtitles to the episode from another source. But now for whatever rare reason, I get an error from MKVMerge saying this:
"This AC3 track contains 227 bytes of non-AC3 data which were skipped. The audio/video synchronization may have been lost."
What exactly is non-AC3 data? And how do I make it so the audio and video syncs correctly? I tried ripping the audio using different programs such as Reijig since it has a ac3 audio correction. But it didn't correct any delay. And the samething happen. The audio is out of sync. So whatever reason, I can't sync the audio to the video no matter what I do in this instance.
Anyone know the problem? And how do I correct it? Because I can't sync subtitles to something that isn't syncd right.
Gui of that program didn't work. But then I just used the exe file and got this:
D:\Apps\Audio editing tools\AC3fixGUI\ac3fixgui>ac3fix AudioFile_80.ac3 AudioFilefix
Starting. Input file is AudioFile_80.ac3, output file is AudioFilefix
Frame length is 1792
Checking frame 3396: Wrong frame length, expected 6082048, got 1792
Writing frame
Current wrongness is -227 bytes
Checking frame 46232: OK
Finished. Found bad frames. Final wrongness is -227 bytes
Apparently it fixed it. But when I put it through mkvmerge. The resulting file still has the audio out of sync(The Mkvmerge error did go away, though). There is some stuff, I still need to try though. I'll let you know how it goes.
update: I had to edit the audio file to actually make it sync'd up. I can't remember what exactly I did. But I used a program like goldwave , and I either inserted audio silence or deleted a little bit of audio to sync it up.Last edited by PSPGamer; 5th Jan 2014 at 20:15. Reason: if anyone comes acrossed I want to show them how I solved the problem
MKVMerge A/V Sync Problem...?
By WellBeSerious12 in forum Video ConversionReplies: 1Last Post: 5th Nov 2011, 19:37 -
Audio out-of-sync in mkv (MkvMerge)
By Sousa_Software in forum Video ConversionReplies: 8Last Post: 3rd Aug 2011, 18:00 -
TsMuxeR AC3 audio track with Narrator problem
By Tony Nguyen in forum Authoring (Blu-ray)Replies: 3Last Post: 11th Dec 2010, 11:27 -
merging .264 with ac3 with mkvmerge goes out of sync
By jylau125 in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 02:55
