I tried to convert this video with mkv2vob to play on my ps3, but when i try to play the video on the playstation the video stutters and the audio is fine. The converted video works fine on my computer. Here is all the info on the original video. Any suggestions?
Format : Matroska
File size : 3.12 GiB
Duration : 2h 19mn
Overall bit rate : 3 210 Kbps
Writing application : HandBrake 0.9.5
Writing library : libmkv 0.6.4.1
Video
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=16
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 19mn
Bit rate : 3 050 Kbps
Width : 1 440 pixels
Height : 1 078 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.079
Stream size : 2.90 GiB (93%)
Writing library : x264 core 112
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=3050 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 19mn
Bit rate mode : Constant
Bit rate : 160 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 159 MiB (5%)
Language : English
Format : Matroska
Duration : 2h 19mn
Results 1 to 1 of 1
Choppy Playback - Suggestions?
By icecold0725 in forum Newbie / General discussionsReplies: 21Last Post: 12th Oct 2010, 09:06 -
Newb with choppy playback, ps3 streaming
By thekid138 in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2009, 15:23 -
Choppy video playback
By dexter30 in forum Newbie / General discussionsReplies: 13Last Post: 6th Nov 2008, 12:10 -
choppy video playback
By RobotFood in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 07:40 -
Choppy Stuttered Playback
By grooveguru in forum ffmpegX general discussionReplies: 4Last Post: 24th May 2007, 11:54
