Okay. i reinstalled nero and now when i take a 620MB (42min) Mpeg-1 file and drag and drop, Nero tells me I'm trying to burn a 773MB file at 84 mins?? what gives, anyone have this problem before. I can't even begin to guess whats happening here. I reinstalled again and yet still the same twisted results????
Anyone? thanks
Nero version 5.5.5.1 (came with mitsumi drive)
Try this: Launch TMPGEnc, go FILE...MPEG Tools...Merge and Cut...Select Type "MPEG1 VideoCD (non-standard) Go Add...add the file...select the output file name and don't change anything else(defaults the whole clip). Hit Run then when done try to load the resulting file into Nero with non-standard VCD option selected. It seems Nero needs the find the appropriate info in the MPEG-1 to correctly recognize the size. No guarantees with your particular file but worth a shot.
you can upgrade the version, if i remember correctly your version had a few vcd related bugs. upgrading nero is free you just have to download it from nero.com
upgrade to 5.5.7.8
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Forum links all messed up
By lordsmurf in forum FeedbackReplies: 4Last Post: 7th Aug 2010, 16:15 -
How weird. Two movies, one ok, one all messed up
By LWC in forum Authoring (DVD)Replies: 2Last Post: 1st Jan 2010, 17:21 -
my DVD and HDD messed up
By goodguyswearblack9 in forum DVD RippingReplies: 8Last Post: 20th Apr 2008, 02:11 -
timecode messed up
By snafubaby in forum EditingReplies: 4Last Post: 20th Sep 2007, 05:00 -
Nero messed up again, need an alternative.
By capman21 in forum ComputerReplies: 5Last Post: 12th Jul 2007, 10:19
