Results 1 to 14 of 14
    Apr 2011
    Computer
    Hello, I used AVStoDVD a year ago, and it worked wonderfully. This time, however, after saying that it had finished successfully, I placed the CD in my DVD player, and it said it could not be read. I took it back to my computer to try and play it there, but when I inserted it, my computer said that the disk was blank. I'm not quite sure what happened, but any help would be much appreciated.
    (And I think my post might be too long with the log included, so I'll post that next.)
    Apr 2011
    Computer
    (Part 1)
    <4/19/2011 2:40:58 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: PAL
    DVD Titles number: 8
    DVD Size: 4450/4450 MB (100%)
    DVD Output Setup: DVD Folder
    DVD Label: FMA Brotherhood 1-8
    DVD Menu: Static Menu
    Output Folder: C:\Users\Robert\Videos
    Delete Temp Process Files: Yes
    Delete Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    MultiThread: 1
    AVS Source Filter: A2DSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 6500
    Video Profile Level 2: 4500
    Video BitRate Max: 8500
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 0
    PAL SpeedUp: 0
    Force FFmpeg for Long Audio: 1
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Audio Language: EN - English
    DVD Subs Language: EN - English
    DVD Subs Font: Tahoma 18pt Bold
    Chapters Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: E: TSSTcorp DVD+-RW TS-H653B D200
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Save Log file: 1
    Save General Settings: 0
    Unload ActiveMovie library: 0
    Adjust ffdshow mixer: 1
    TITLE 1 SOURCE FILES
    Video: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C].avi
    Info: XviD - 1188 kbps - 704x400 - DAR 1.76 - 23.976 fps (CFR) - Progressive - 24:29 minutes - 35236 frames
    Audio 1: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C].avi
    Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2ch - 48000Hz - 24:29 minutes - Internal
    Subs:
    [MediaInfoLib - v0.7.41]
    AVISYNTH SCRIPT
    Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp", FrameRate=23.976, VFR=false)
    Audio = A2DAudioSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp")
    Video = Video.ConvertToYV12
    #Using DGPulldown/HCenc to upsize FPS
    Video = Video.AddBorders(0,64,0,64)
    Video = Video.Lanczos4Resize(720,576)
    AudioDub(Video, Audio)
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: HCenc VBR 2-pass
    Target Video FileSize: 502.2 MB
    HCenc Parameters: -ini "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C].HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C]_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C].m2v
    *LOGFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C].HCenc.log
    *MAXBITRATE 9000
    *BITRATE 2866
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <4/19/2011 3:07:18 PM>
    END VIDEO ENCODING OPERATIONS
    A2DVideoSource: AVISource
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C].m2v (502.5 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 2887 kbps - 720x576 - DAR 1.333 - 23.976 fps (CFR) - Progressive (TFF) - 24:28 minutes - 35201 frames
    START PULLDOWN OPERATIONS
    DGPulldown Parameters: "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C].m2v" -srcfps 23.976 -destfps 25 -inplace -tff
    <4/19/2011 3:09:26 PM>
    END PULLDOWN OPERATIONS
    DGPulldown executed on File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C].m2v (502.5 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 2885 kbps - 720x576 - DAR 1.333 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 24:29 minutes - 35270 frames
    <4/19/2011 3:09:30 PM>
    START AUDIO ENCODING OPERATIONS (Track 1)
    Wavi+Aften Parameters: "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C]_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C]_1.ac3"
    <4/19/2011 3:12:30 PM>
    END AUDIO ENCODING OPERATIONS (Track 1)
    A2DAudioSource: DirectShowSource
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C]_1.ac3 (33.6 MB)
    OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2ch - 48000Hz - 16bit - 24:29 minutes
    <4/19/2011 3:12:32 PM>
    TITLE 2 SOURCE FILES
    Video: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911].avi
    Info: XviD - 1188 kbps - 704x400 - DAR 1.76 - 23.976 fps (CFR) - Progressive - 24:29 minutes - 35234 frames
    Audio 1: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911].avi
    Subs:
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp", FrameRate=23.976, VFR=false)
    Audio = A2DAudioSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp")
    HCenc Parameters: -ini "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911].HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911]_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911].m2v
    *LOGFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911].HCenc.log
    *MAXBITRATE 9000
    *BITRATE 2866
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <4/19/2011 3:38:35 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911].m2v (502.4 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 2887 kbps - 720x576 - DAR 1.333 - 23.976 fps (CFR) - Progressive (TFF) - 24:28 minutes - 35199 frames
    DGPulldown Parameters: "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911].m2v" -srcfps 23.976 -destfps 25 -inplace -tff
    <4/19/2011 3:40:38 PM>
    DGPulldown executed on File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911].m2v (502.4 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 2884 kbps - 720x576 - DAR 1.333 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 24:29 minutes - 35268 frames
    <4/19/2011 3:40:40 PM>
    Wavi+Aften Parameters: "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911]_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911]_1.ac3"
    <4/19/2011 3:44:49 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911]_1.ac3 (33.6 MB)
    <4/19/2011 3:44:50 PM>
    TITLE 3 SOURCE FILES
    Video: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64].avi
    Audio 1: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64].avi
    Subs:
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp", FrameRate=23.976, VFR=false)
    Audio = A2DAudioSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp")
    HCenc Parameters: -ini "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64].HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64]_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64].m2v
    *LOGFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64].HCenc.log
    *MAXBITRATE 9000
    *BITRATE 2866
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <4/19/2011 4:10:57 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64].m2v (502.4 MB)
    DGPulldown Parameters: "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64].m2v" -srcfps 23.976 -destfps 25 -inplace -tff
    <4/19/2011 4:14:35 PM>
    DGPulldown executed on File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64].m2v (502.4 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 2884 kbps - 720x576 - DAR 1.333 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 24:29 minutes - 35270 frames
    <4/19/2011 4:14:37 PM>
    Wavi+Aften Parameters: "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64]_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64]_1.ac3"
    <4/19/2011 4:17:06 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64]_1.ac3 (33.6 MB)
    <4/19/2011 4:17:08 PM>
    TITLE 4 SOURCE FILES
    Video: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690].avi
    Info: XviD - 1200 kbps - 704x400 - DAR 1.76 - 23.976 fps (CFR) - Progressive - 24:14 minutes - 34879 frames
    Audio 1: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690].avi
    Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2ch - 48000Hz - 24:14 minutes - Internal
    Subs:
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp", FrameRate=23.976, VFR=false)
    Audio = A2DAudioSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp")
    Target Video FileSize: 497.1 MB
    HCenc Parameters: -ini "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690].HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690]_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690].m2v
    *LOGFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690].HCenc.log
    *MAXBITRATE 9000
    *BITRATE 2866
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <4/19/2011 4:45:19 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690].m2v (497.3 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 2887 kbps - 720x576 - DAR 1.333 - 23.976 fps (CFR) - Progressive (TFF) - 24:13 minutes - 34844 frames
    DGPulldown Parameters: "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690].m2v" -srcfps 23.976 -destfps 25 -inplace -tff
    <4/19/2011 4:46:25 PM>
    DGPulldown executed on File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690].m2v (497.3 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 2884 kbps - 720x576 - DAR 1.333 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 24:14 minutes - 34913 frames
    <4/19/2011 4:46:28 PM>
    Wavi+Aften Parameters: "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690]_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690]_1.ac3"
    Apr 2011
    Computer
    (Part 2)
    <4/19/2011 4:52:10 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690]_1.ac3 (33.3 MB)
    OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2ch - 48000Hz - 16bit - 24:14 minutes
    <4/19/2011 4:52:12 PM>
    TITLE 5 SOURCE FILES
    Video: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F].avi
    Audio 1: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F].avi
    Subs:
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp", FrameRate=23.976, VFR=false)
    Audio = A2DAudioSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp")
    <4/19/2011 4:52:13 PM>
    HCenc Parameters: -ini "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F].HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F]_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F].m2v
    *LOGFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F].HCenc.log
    *MAXBITRATE 9000
    *BITRATE 2866
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <4/19/2011 5:19:44 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F].m2v (502.4 MB)
    DGPulldown Parameters: "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F].m2v" -srcfps 23.976 -destfps 25 -inplace -tff
    <4/19/2011 5:20:21 PM>
    DGPulldown executed on File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F].m2v (502.4 MB)
    <4/19/2011 5:20:24 PM>
    Wavi+Aften Parameters: "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F]_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F]_1.ac3"
    <4/19/2011 5:49:57 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F]_1.ac3 (33.6 MB)
    <4/19/2011 5:49:58 PM>
    TITLE 6 SOURCE FILES
    Video: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26].avi
    Audio 1: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26].avi
    Subs:
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp", FrameRate=23.976, VFR=false)
    Audio = A2DAudioSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp")
    HCenc Parameters: -ini "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26].HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26]_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26].m2v
    *LOGFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26].HCenc.log
    *MAXBITRATE 9000
    *BITRATE 2866
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <4/19/2011 6:14:53 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26].m2v (502.4 MB)
    DGPulldown Parameters: "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26].m2v" -srcfps 23.976 -destfps 25 -inplace -tff
    <4/19/2011 6:15:49 PM>
    DGPulldown executed on File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26].m2v (502.4 MB)
    <4/19/2011 6:15:51 PM>
    Wavi+Aften Parameters: "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26]_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26]_1.ac3"
    <4/19/2011 6:18:40 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26]_1.ac3 (33.6 MB)
    <4/19/2011 6:18:41 PM>
    TITLE 7 SOURCE FILES
    Video: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579].avi
    Audio 1: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579].avi
    Subs:
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp", FrameRate=23.976, VFR=false)
    Audio = A2DAudioSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp")
    HCenc Parameters: -ini "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579].HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579]_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579].m2v
    *LOGFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579].HCenc.log
    *MAXBITRATE 9000
    *BITRATE 2866
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <4/19/2011 6:43:52 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579].m2v (502.4 MB)
    DGPulldown Parameters: "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579].m2v" -srcfps 23.976 -destfps 25 -inplace -tff
    <4/19/2011 6:44:41 PM>
    DGPulldown executed on File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579].m2v (502.4 MB)
    <4/19/2011 6:44:44 PM>
    Wavi+Aften Parameters: "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579]_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579]_1.ac3"
    <4/19/2011 6:47:22 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579]_1.ac3 (33.6 MB)
    <4/19/2011 6:47:23 PM>
    TITLE 8 SOURCE FILES
    Video: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64].avi
    Audio 1: C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64].avi
    Subs:
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp", FrameRate=23.976, VFR=false)
    Audio = A2DAudioSource("C:\Users\Robert\Desktop\FMA Brother\[Eclipse] Fullmetal Alchemist Brotherhood (XviD)\[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64].avi", CacheFolder="C:\Users\Robert\AppData\Local\Temp")
    HCenc Parameters: -ini "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64].HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64]_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64].m2v
    *LOGFILE C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64].HCenc.log
    *MAXBITRATE 9000
    *BITRATE 2866
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <4/19/2011 7:12:41 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64].m2v (502.5 MB)
    DGPulldown Parameters: "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64].m2v" -srcfps 23.976 -destfps 25 -inplace -tff
    <4/19/2011 7:13:38 PM>
    DGPulldown executed on File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64].m2v (502.5 MB)
    <4/19/2011 7:13:40 PM>
    Wavi+Aften Parameters: "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64]_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64]_1.ac3"
    <4/19/2011 7:16:10 PM>
    Created File: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64]_1.ac3 (33.6 MB)
    <4/19/2011 7:16:15 PM>
    START DVD MENU BUILDING OPERATIONS
    DVD Menu settings:
    Style: 0
    Aspect Ratio: 0
    Titles Format: 1
    Template: Menu in Black
    Max Titles Page: 12
    Enable Play All: 1
    Force Play All: 0
    Background Audio: 0
    Max Thumbs Row: 4
    Thumb Frame Position: 10%
    HL Frame Format: 0
    HL Selection Color: 8
    HL Play Color: 0
    Menu Video BitRate: 6000 kbps
    Motion Menu Duration: 15 seconds
    Thumb Drop Shadow: 2
    Play All Shadow: 2
    Arrows Shadow: 0
    <4/19/2011 7:16:58 PM>
    END DVD MENU BUILDING OPERATIONS
    Created File (Menu Page 1): C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_MenuPage1.bmp (1.2 MB)
    <4/19/2011 7:16:59 PM>
    START DVD AUTHORING OPERATIONS
    BatchMux Parameters: -arglist "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_BatchMux.ini"
    BatchMux ini file:
    -d "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0\VIDEO_TS"
    -mxp "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_MuxMan.mxp"
    -l "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_MuxMan.log"
    -muxman "C:\Program Files\AVStoDVD\MuxMan"
    -prio LOW
    -v "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C].m2v"
    -vidmode 4:3
    -a1 "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C]_1.ac3"
    -a1lang en
    -cellfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C]_Chapters.txt"
    -progfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C]_Chapters.txt"
    -chapfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_01_[Eclipse] Fullmetal Alchemist Brotherhood - 01 (XviD) [16B3DC8C]_Chapters.txt"
    -SEG2v "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911].m2v"
    -SEG2vidmode 4:3
    -SEG2a1 "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911]_1.ac3"
    -SEG2a1lang en
    -SEG2cellfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911]_Chapters.txt"
    -SEG2progfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911]_Chapters.txt"
    -SEG2chapfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_02_[Eclipse] Fullmetal Alchemist Brotherhood - 02 (XviD) [3D3D8911]_Chapters.txt"
    -SEG3v "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64].m2v"
    -SEG3vidmode 4:3
    -SEG3a1 "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64]_1.ac3"
    -SEG3a1lang en
    -SEG3cellfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64]_Chapters.txt"
    -SEG3progfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64]_Chapters.txt"
    -SEG3chapfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_03_[Eclipse] Fullmetal Alchemist Brotherhood - 03 (XviD) [93B77D64]_Chapters.txt"
    -SEG4v "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690].m2v"
    -SEG4vidmode 4:3
    -SEG4a1 "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690]_1.ac3"
    -SEG4a1lang en
    -SEG4cellfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690]_Chapters.txt"
    -SEG4progfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690]_Chapters.txt"
    -SEG4chapfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_04_[Eclipse] Fullmetal Alchemist Brotherhood - 04 (XviD) [BD914690]_Chapters.txt"
    -SEG5v "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F].m2v"
    -SEG5vidmode 4:3
    -SEG5a1 "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F]_1.ac3"
    -SEG5a1lang en
    -SEG5cellfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F]_Chapters.txt"
    -SEG5progfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F]_Chapters.txt"
    -SEG5chapfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_05_[Eclipse] Fullmetal Alchemist Brotherhood - 05 (XviD) [2A33391F]_Chapters.txt"
    -SEG6v "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26].m2v"
    -SEG6vidmode 4:3
    -SEG6a1 "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26]_1.ac3"
    -SEG6a1lang en
    -SEG6cellfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26]_Chapters.txt"
    -SEG6progfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26]_Chapters.txt"
    -SEG6chapfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_06_[Eclipse] Fullmetal Alchemist Brotherhood - 06 (XviD) [212C4D26]_Chapters.txt"
    -SEG7v "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579].m2v"
    -SEG7vidmode 4:3
    -SEG7a1 "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579]_1.ac3"
    -SEG7a1lang en
    -SEG7cellfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579]_Chapters.txt"
    -SEG7progfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579]_Chapters.txt"
    -SEG7chapfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_07_[Eclipse] Fullmetal Alchemist Brotherhood - 07 (XviD) [BDF53579]_Chapters.txt"
    -SEG8v "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64].m2v"
    -SEG8vidmode 4:3
    -SEG8a1 "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64]_1.ac3"
    -SEG8a1lang en
    -SEG8cellfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64]_Chapters.txt"
    -SEG8progfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64]_Chapters.txt"
    -SEG8chapfr "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Title_08_[Eclipse] Fullmetal Alchemist Brotherhood - 08 (XviD) [311B3C64]_Chapters.txt"
    -SEG9v "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_MenuPage1.bmp"
    -SEG9vidmode 4:3
    -SEG9s1 "C:\Users\Robert\Videos\FMA Brotherhood 1-8_0_Menu.sst"
    -SEG9s1dmode LB
    -SEG9hlmnu "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_MenuPage1_Buttons.mnu"
    -SEG9hlcsm "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_HighlightScheme.csm
    -hcn "C:\Users\Robert\AppData\Local\Temp\FMA Brotherhood 1-8_0_BatchMux.hcn"
    <4/19/2011 7:31:15 PM>
    CHECK DVD SIZE
    DVD Folder (actual) Size: 4404.1 MB
    vs Estimated Size: 4450 MB -> 1.0% undersize
    vs Assets Size: 4284.2 MB -> OK
    END DVD AUTHORING OPERATIONS
    Created Folder: C:\Users\Robert\Videos\FMA Brotherhood 1-8_0 (4404.1 MB)
    <4/19/2011 7:31:18 PM>
    Log file created by AVStoDVD Release 2.3.4
    Jul 2009
    Are you sure you had AVStoDVD set to burn when done? There isn't anything in that log that would indicate that it tried to burn the results to DVD.
    Apr 2011
    Computer
    Hm... I thought that I did. What would you advise that I do now? I do have a folder that was created from this.
    Mar 2008
    You open IMGBURN, select burn files and folder, and drag the video_ts folder to the program.
    Burn the disk.
    Apr 2011
    Computer
    Thank you, everyone, it worked. During the verification, I got some errors about "miscompares", but it looks like everything works. I guess I was used to AVStoDVD burning on its own at the end. I must have set it to a long time ago, and it reset when I re-downloaded it for the latest version.
    Mar 2008
    A bad file verify may be due to crap media, or possibly burned at too high a rate.
    For example, try 8x or 12x on 16x media.
    Apr 2011
    Computer
    Hm, I see, thank you. Do you think that this might have an impact on the DVD? I only watched one video, but both video and audio seemed fine. I did not watch it all the way through, though.
    Apr 2011
    Computer
    (For the record, I had it on AWS, but I have no idea what I should be using for these CDs.)
    Mar 2008
    Put one of the media in the drive. Open Imgburn/burn files and folders.
    Look at the device tab. Among the details there, you'll find all the speeds the media can support.
    Try using one of the slower speeds as I mentioned before.
    Apr 2011
    Computer
    Oddly, though it worked on the computer, when I put the CD into the DVD player, it seemed to read it, and the screen went to black and said "DVD", but then it simply said "Cannot Play". I wonder if reburning it slowly as you said, might fix that.
    Mar 2008
    The other remedy is to buy some decent media. On the device tab the media ID is reported. You can do a search in videohelp.com
    and see what experience others have had with it. It'll say something like Disk ID: xxxxxxx
    Apr 2011
    Computer
    These CDs probably aren't top of the line, but they worked on the first try last year, when I did something almost exactly like this. I'll keep trying, though, thank you.
