I’m trying to save the audio from an flv file and put it on a CD. I’m using Avidemux (vers 2.5.4) which someone suggested. The tutorials mention saving the audio in one of many formats including wav. Problem is that wav is not showing up for me in the Audio/video sidebar.
What steps am I missing? Is there some other format and/or settings that I can use? I personally never recorded anything using MP3, AC3, etc., so my knowledge of what can be done with these is limited.
Any suggestions would be appreciated.
Thanks in advance.
				Results 1 to 30 of 31
	Format Factory 2.6 is free ... use it to convert flv to mpg or avi ... than send it to Virtualdub [free also] ... use Virtualdub to extract the wav file ... done.
	would flvextractor work for this?
 Also couldn't you use the directshowsource avisynth template to open the flv directly in virtualdub without converting?
 edit - I couldn't find flvextractor in the tools section. I know there is some kind of tool to strip a flv file.... don't remember the name apparently.
 edit 2 - also another realtime option is to use audacity (freeware) and just record "what u hear" from your computer and save as a wav file that way. It should record exactly what is playing.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	I'm pretty sure AVIdemux works. Open the source file. On the left, change audio from "copy" to wav/pcm.
 At the top, select audio/save.
 Of course, if you want to make a real audio CD (redbook) the audio should be 44.1Khz @16 bit.
 If you're just copying the files as data, it can be anything your playback device can handle.
	Avidemux does work quite well & is easy to use. I just don’t know all the particulars of the different formats.
 I tried PCM & the “Configure” function does nothing. No menu appears. I’m presuming that’s because if anything was changed then it would not be PCM. If I save as .pcm some programs do not recognize it. Saving as .wav worked every time. Media Info shows the PCM/WAV file as 1,411.2 Kbps, 44.1 KHz, 16bits, 2 Channels, PCM (Microsoft). The original flv was 118 Kbps, 44.1 KHz, 16bits, 2 Channels, AAC (Version4) (LC).
 I tried MP3 (lame) & “Configure” then gave some options, with the default Bitrate of 128. And MediaInfo does show the saved audio file as 128 Kbps, 44.1 KHz, 2 Channels, MPEG Audio (Version 1) (Layer 3).
 Trying to figure out a few things I found that 1,411.2 Kbps is the Red Book audio specification. Since this will end up on a CD-R, is there an advantage of using the PCM audio which creates the 1,411.2 Kbps file to start with?
 If I use MP3 is there any advantage to using anything higher than 128 Kbps since the original was 118 Kbps?
 So an MP3 can be burned to a CD-R as a data file, but it appears it can also be converted to 1,411.2 Kbps when creating & burning to a CD-R. IOW it can be done either way, is that correct?
 Thanks again.
	Yes of course it can be done either way, if you write the mp3 (or any other file, for that matter) to the disk as data,
 then that's what you get. An exact representation,.bit for bit.
 However, redbook audio CD is similar to wav/pcm in it's specification. I have nero 6 installed and if you open an
 audio CD project and add mp3 files, it dynamically converts them to Wav before writing the disk.
 If you create an audio CD from WAV files, the data is not changed . The problem with saving mp3 out of AVidemux
 is you lower the sound quality a second time (the first was when the aac was originally created) But if you save it as
 Wav, the sound quality is kept intact.
 Hope this answers your question.
	davexnet,
 Thanks for the answer.
 Now I have a different problem with a couple other flv files. I cannot adjust the volume, it is fixed. And the audio is distorted.
 MediaInfo indicates the Video Stream is AVC with the following details.
 212 Kbps, 640x480 (4:3), at 30.000fps, AVC (Container profile=Unknown@3.0) (Main@L3.0) (CABAC / 3 Ref Frames)
 Audio appears to be normal AAC.
 The Avidemux properties appear pretty much the same as the other flv files I played with except the image is 640x480 vs. 320x240.
 I tried various settings but to no avail. The only thing that I can find when searching is that AVC does not appear to be supported.
 Any suggestions?
	You're probably thinking of FLV Extract. Drop the FLV on it, demux the audio stream, done.  If cameras add ten pounds, why would people want to eat them? If cameras add ten pounds, why would people want to eat them?
	Looking into this a bit more, the videos I have problems with have a video stream similar to this.
 The ones that work OK are similar to this.
 63.3 Kbps, 320x240 (4:3), at 30.000fps, AVC (Container profile=Unknown@1.3) (Main@L1.3) (CABAC / 3 Ref Frames)
 What you notice immediately is the size of the image when Avidemux opens the file. And as mentioned the audio is fixed (at a low level) and is distorted on the problem ones.
 AVC does work with the smaller image size videos, so I’m guessing AVC is not the issue. I’m guessing that “(Container profile=Unknown@3.0) (Main@L3.0)” is the problem. IOW the “1.3” parameter works but the “3.0” does not. I have no idea what that means.
 If FLV Extract is used it appears the audio would still need to be converted to PCM/WAV. Not a problem, but it would be nice to be able to use just one program to do the job. Hopefully there is a simple solution.
	you can try vdub with the flv plugin , and aac acm
 if the file is normal, not corrupted, avisynth will work for practically everything with soundout() . You can use normalize() to normalize the volume
 if avidemux won't let you adjust volume, if you can still save as pcm wav, then you can adjust volume in another audio program
	yoda313,
 All 9 of the flv files I have played with have AAC audio. Avidemux did extract & save as PCM/WAV audio with 4 of the files. IOW it is capable of doing both jobs, at least some of the time. Question is why not all the time.
 I did try looking at the Avidemux forum, but every subject or thread I click on gives me an error message saying I need to enable "DEBUG mode", etc. I have no idea what that has to do with looking at a forum.
	Without having the files to test personally its hard to say. Though a guess could be variable bit rate audio? I have read countless times about the problems vbr audio creates. I haven't personally dealth with it to my knowledge but that is a recurring theme here on this website regarding audio issues.Originally Posted by mike99
 Frankly I'm not sure what the real problem is. Working with audio is usually a breeze compared to processing video. And personally I don't know why its a problem working with two or more programs. As long as you get it done that is all that matters. Streamlining is of course beneficial but if it doesn't work 100% of the time you have to bite the bullet and use more programs.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	yodo313,
 I don’t have a problem using multiple programs if that’s what it takes. It’s just that Avidemux started out as a nice one-step program. And then davexnet mentioned saving as an mp3 first and then converting to WAV lowers the sound quality, if I understand that correctly. That makes sense because of the double conversion.
 The audio formats all look the same except for size and bitrate, at least according to MediaInfo.
 But the video format Container profile and Main parameters are different. That’s the only thing that I noticed. I did some searching trying to find out what those meant and came up empty handed. I'm curious so will look a bit more.
	AVC profile doesn't matter, that only affects the video. You're barking up the wrong tree
	Here’s MediaInfo for two videos, one plays properly in Avidemux and one does not.
 This one does play properly using Avidemux.
 Video
 Format : AVC
 Format profile : Main@L1.3
 Format settings, CABAC : Yes
 Format settings, ReFrames : 3 frames
 Muxing mode : Container profile=Unknown@1.3
 Duration : 5mn 16s
 Bit rate : 63.3 Kbps
 Width : 320 pixels
 Height : 240 pixels
 Display aspect ratio : 4:3
 Frame rate mode : Constant
 Frame rate : 30.000 fps
 Color space : YUV
 Chroma subsampling : 4:2:0
 Bit depth : 8 bits
 Scan type : Progressive
 Bits/(Pixel*Frame) : 0.027
 Stream size : 2.38 MiB (33%)
 Audio
 Format : AAC
 Format version : Version 4
 Format profile : LC
 Format settings, SBR : No
 Duration : 5mn 16s
 Bit rate : 118 Kbps
 Channel(s) : 2 channels
 Sampling rate : 44.1 KHz
 Bit depth : 16 bits
 Stream size : 4.44 MiB (62%)
 This one does not play with proper audio in Avidemux. It does play properly using VLC.
 Video
 Format : AVC
 Format profile : Main@L3.0
 Muxing mode : Container profile=Unknown@3.0
 Duration : 2mn 45s
 Bit rate : 212 Kbps
 Width : 640 pixels
 Height : 480 pixels
 Color space : YUV
 Bit depth : 8 bits
 Bits/(Pixel*Frame) : 0.023
 Stream size : 4.20 MiB (67%)
 Audio
 Format : AAC
 Format profile : LC
 Duration : 2mn 45s
 Bit rate : 96.5 Kbps
 Bit depth : 16 bits
 Stream size : 1.91 MiB (30%)
 Any thoughts why the audio is fixed & distorted?
	Losing one's sense of humor....
 is nothing to laugh at.
	Interesting that you should mention this as I did try VLC a bit earlier and it did the job. Initially it did not work on 2 videos. I tried several times and it just did nothing. I got tired of using the original long filename & shortened it quite a bit and then it worked on all of them. There does not appear to be a way to edit or trim the files. But it extracts & saves to wav in one quick process.
	I just tried AoA Audio Extractor.
 I selected wav output & tried it on a couple of the problematic videos. It did extract the audio but did not create a CD compliant wav/pcm file.
 Here’s what it made per MediaInfo.
 Audio
 Format : PCM
 Codec ID : 1
 Codec ID/Hint : Microsoft
 Duration : 3mn 18s
 Bit rate : 1 536 Kbps
 Sampling rate : 48.0 KHz
 Bit depth : 16 bits
 Stream size : 36.3 MiB (100%)
 It had the typical choices of 128, 192, etc for the audio, but I did not see any settings for creating a 1,411.2 Kbps, 44.1 Khz file. It just did the 1,536 Kbps and 48.0 KHz by itself.
	Hi
 I wasn't sure what you were trying to achieve before.
 If you want to use the audio from some flv files to make an Audio CD then WinFF is ideal for the job.
 From here:- http://winff.org/html_new/
 It's very easy to use.
 It has options:-
 Convert to... Audio
 Device Preset... Wav for CD
 This is the result:-
 Code:General Complete name : filename.wav Format : Wave File size : 38.6 MiB Duration : 3mn 49s Overall bit rate : 1 411.2 Kbps Audio ID : 0 Format : PCM Codec ID : 1 Codec ID/Hint : Microsoft Duration : 3mn 49s Bit rate : 1 411.2 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Bit depth : 16 bits Stream size : 38.6 MiB (100%)
	I tried WinFF and it works quite well. Fast & simple.
 Comparing the WinFF wav files to the ones made using VLC, they are the same exact size. Are they both using the same codec? However these are just very slightly larger than the Avidemux files.
 I like Avidemux because you can edit/trim the source video before extracting/converting the audio. The downside is that it did not work with half of the flv files I tried.
 WinFF and VLC are pretty equivalent in ease of use & functionality.
 Between these three, would one of them supposedly make a more accurate or better sounding audio file? I can’t tell the difference but maybe someone else can.
	@mike99 - as far as trimming all you have to do is trim after you get the wav file. Any audio editor can do that - audacity for example.
 Regarding the codec - it should all be pcm wav at 16 bit 44.1 khz. If its cd audio output that you specify that is all the choice available.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	You can also use Virtualdub with fcchandler's FLV plugin and AACACM. Open the file > trim if needed > Audio > Full Compression Mode > File > Save WAV.
 http://fcchandler.home.comcast.net/~fcchandler/Plugins/FLV/FLV.zip
 http://fcchandler.home.comcast.net/~fcchandler/AACACM/index.html
	I'll give Audacity a try. I already have it but never used it.
 yoda313 -
 I probably did not word my question properly. Do different programs use different means to get to the same end, the wav file? There's obviously a conversion taking place & are some conversion methods or algorithms better than others?
  FLV audio out of sync, can't work VirtualDub w/ FLV pluginBy ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 12:51
  Extracting audio from .tsBy leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 17:22
  Extracting Music from Audio CDBy prayami in forum AudioReplies: 4Last Post: 4th Aug 2008, 18:59
  Extracting audio with VirtualDubBy RedPenguin in forum Newbie / General discussionsReplies: 12Last Post: 16th Dec 2007, 20:03
  Extracting audio from AVI'sBy KoolDrew in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 21:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
