I save out 2 clips into huffyuv format exact same setting, BEST setting. Both pcm audio 44100 stereo. I try to join in vdub and it says dif dat formats. SO I try avisynth it says the same thing, dif data formats. So I .converttoyv12 in avisynth and they join fine. Why the hell is this happening? I'd rather not waste processing time inserrting .converttoyv12 on every edit I make.
(I make alot of hufyuv videos and join them for the final compress)
  converting raw teltext data into other subtitle formatsBy zorr00000 in forum SubtitleReplies: 8Last Post: 18th Jan 2012, 06:12
  VDub "incompatible data formats" errorBy coyote2 in forum EditingReplies: 10Last Post: 1st Nov 2011, 12:28
  Export HDV clips to SD clips from Premiere Pro CS3By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 18:03
  VirtualDub Error: The audio streams have incompatible data formatsBy UMO in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2010, 03:38
  Vista compatible mpeg joiner where 2 clips have diff dimensions?By wetcamelfood in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2009, 14:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
