Results 1 to 13 of 13
    Mar 2011
    Italy
    Currently I am using Cyberlink Powerdirector 9.
    Have you got better suggestions?
    thanks in advance!
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    windv is usually recommended on this site.
    Mar 2011
    Italy
    I saw that it is a pretty old utility. Will it work properly with Windows 7 x64?
    Thanks!
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    It is still recommended so I assume it is.
    All else fails you can cap to dv-avi in windows movie maker.
  5. Works fine with Windows 7 x64.
    Mar 2011
    Italy
    Thanks!
    No option to stop capturing after a given time though...
  7. Member DB83's Avatar
    Jul 2007
    Thanks!
    Well there is but you need a calculator. You can set the maximum AVI size in frames.
  8. It doesn't really matter what you capture DV AVI with, as long as it works. The quality will be the same. All the software is doing is taking the already compressed video stream from the ADVC and putting it in an AVI wrapper.
    Oct 2006
    Hi,
    I've used the free non-commercial version of Enosoft with excellent results for some time now.
    You might want to give it a try. The program even has some editing ability built in.
    It's at:
    www.enosoft.net
    Hope this helps!
    Fred
  10. Enosoft does have one advantage: It can adjust the brightness and contrast of the DV video while capturing without decompressing and recompressing it and thereby avoiding any quality loss. Technically, it does decompress/recompress the entropy encoding but that portion is lossless.
    Aug 2010
    San Francisco, California
    I use Sony Video Capture, which comes with the Vegas editing package. I wrote a script in AutoHotkey to take a value in minutes and stop the capture at the end of that time. (AutoHotkey is a great keyboard/mouse automator, and it's free.)
    Sep 2007
    I always used AVI_IO with my ADVC-100. Never had any problems with dropped frames. Not sure if it will run under Win7.
    rcubed
    Feb 2010
    Michigan USA
    Not sure about the other software mentioned but WinDV will stop writing to disk whenever the video stops. That means you can do unattended captures of recordings of unknown length from VHS. When the tape ends the file stops being written. This is with a Panasonic AG-1970 which doesn't output anything when the tape is stopped. Not sure what happens if your VCR outputs something like a solid blue screen when the tape is stopped.
    WinDV is also pretty straighforward about where it stores the file and what it is called. You have full and intuitive control. That was a complaint I had about some other software.... it made it difficult to figure out where the file was written and/or what it was called.
    My only complaint is that it doesn't seem possible to monitor the audio during capture.
    Paul
