All of my captures using VirtualDub with the AverTV HD DVR have resulted in videos with the audio about 75ms ahead of schedule. I suspect that 75ms is approximately how long it takes the HD DVR to convert what it's getting into the 4:2:2 subsample iteration.
For the time being, I've been making do with manual adjustments in Premiere Pro or whatever. But it would be far more convenient if I could tell VirtualDub that the capture card is inadequate in certain ways and the input needs to be adjusted accordingly.
The "Audio Latency Determination" option seems to do nothing at all...
Does the audio latency setting work if you set a fixed value? I've never tried it.
AverTV HD DVR drivers
By Edged in forum Capturing and VCRReplies: 28Last Post: 20th Aug 2015, 10:36 -
So how do I use VirtualDub to capture from the AverTV HD DVR?
By Asterra in forum Capturing and VCRReplies: 55Last Post: 16th Feb 2014, 00:42 -
AverTV HD DVR video glitches
By FTW in forum Capturing and VCRReplies: 8Last Post: 2nd May 2011, 13:40 -
AverTV HD DVR - Some questions
By Asterra in forum Capturing and VCRReplies: 8Last Post: 10th Apr 2011, 16:00 -
Do I have the right slots for the Avertv HD DVR?
By MichaelEatsWaffles in forum Capturing and VCRReplies: 2Last Post: 11th May 2010, 23:42
