Why is my DivX dark? I tried changing the brightness from the decoder but it gives a run32dll error. And in windows Media player i cant go to properties and do anything cause i dont have the advance tab they speak of... Any help?
In media player select view then now playing tools then select equalizer and settings. Then turn up the brightness.
What you have to do is in tmpgnc under the advance tab select simple color you will see a brightness tab for you picture. Also you will notice a scroll bar so you can advance you movie to where you want then slide the brightness bar to where you want. Make sure the box in simple color is checked. To open simple color just double click.
Very Dark Vid
By p0l0levu in forum RestorationReplies: 2Last Post: 27th Feb 2012, 12:53 -
Help with The Dark Knight
By sf49ers in forum Blu-ray RippingReplies: 4Last Post: 10th Mar 2010, 23:29 -
Playback on TV is too dark.
By aah in forum DVB / IPTVReplies: 1Last Post: 16th Nov 2009, 04:01 -
Videos Too Dark on PC
By DarrellS in forum Software PlayingReplies: 10Last Post: 27th Jul 2009, 07:59 -
Dark Video
By jan9ella in forum RestorationReplies: 14Last Post: 27th Jun 2008, 15:43
