HI,
My DVD reader/writer (+RW) doesn't work anymore. It used to work a few weeks ago. Now, I can't even read DVDs I burnt earlier nor burn any DVD. I can still read/write CDs though.
I heard that DVD writer manufacturers programme these hardwares to become obsolete after a certain number of re-installations of Windows. It probably is my case since it stopped all the sudden after a fresh installation of Windows without any prior sign of disfunctionning.
If it is true, is there any way to make my DVD writer work again? If yes, how?
Can anyone suggest a good site for downloading NEC ND-1000A driver? (NEC official site doesn't provide anymore)
Thanks for your reply.
Kamyogi
My OS: Windows XP Family
DVD Writer: NEC ND-1000A
That thing must be ancient since I don't think they even come with drivers anymore.
Try:
1) Going into BIOS and making sure everything is enabled pertaining to the drive
2) Google NEC ND-1000A driver
3) Consider buying a new modern burner for a whopping $20 -
I presume you checked your cable connections, i.e. disconnect/reconnect data and power cables with the computer off.
If the drive has disappeared due to the installation of conflicting burning software, delete the pertinent upper and lower filters from the registry. (Google "upper+lower filters" if this applies to you).
New DVD burners are really cheap you know. I could get, oh, at least 8 of 'em for what my first one cost me.
Pull! Bang! Darn! -
you can get a new one for $18 online..shipped...just get another one
Kamyogi,
If I remember correctly the laser used for CD R/W is different from the one used for DVD r/w. It is probably the DVD laser that has gone bad. As people have mentioned earlier if it isn't a driver or software conflict buy a new drive, they are cheap these days.
My personal preference would be for the drives be a little more expensive and offer a longer life and be more reliable. I have a Plextor CD reader that is over 10yrs old and still works just file. The drives I have purchased over the last few years seem to last only about 3 years. I use ImgBurn and look at the burn graphs and then I run programs to check the quality of the burns each time to determine if the writer is starting to fail. I also verify the data after each burn. Looking at the read error graphs can also show if a burn is questionable. The DVD may be readable, but have high error rates. Otherwise one might put a backup disk on the shelf and then find out later it was not a quality burn. Maybe I'm anal retentive, but I have very few failures with archived DVDs and CDs. A lot of them are 8-10 years old. The media used also makes a difference. Use Tayio Yuden or Verbatim Data Life (not the Value series).
rcubed
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
Please help! New DVD player doesn't work :(
By confuzedinTN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Sep 2010, 14:44 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58 -
Prototype HD DVD-R Writer seems to work fine.
By videopoo in forum Authoring (DVD)Replies: 3Last Post: 31st Dec 2007, 18:52 -
What am doing wrong ? HD DVD using PowerDVD doesn't work
By NICEBUD in forum Software PlayingReplies: 12Last Post: 5th Nov 2007, 03:28
