  1. I have a canon ixus100 whixh can take 720-video. in the settings one can choose NTSC or PAL. As I am in Europe I have PAL.
    I tried both and took a small testfilm. Why are both films 30fps? I thought PAL had 25fps?
  2. Member DB83's Avatar
    Jul 2007
    Post the Media Info report so that we can get a better idea of the issue.
  3. I have used AVSvideoconverter and received the following info as per file enclosed.
    Try mediainfo instead.
    Oct 2010
    England
    I've downloaded the manual for the 'IXUS 100is'. In the specifications section at the end it lists 3 recording modes - all 30fps:
    1280x720 30fps
    640x480 30fps
    320x240 30fps
    The NTSC/PAL option is probably for the 'video out' socket - when plugging your camera directly into your TV. It doesn't look like it's possible to change the actual frame-rate for videos.
  6. Yes it must be Video out. That also explains why the camera does not give a good quality on dvd. I have to convert to 25fps as in PAL and then it is much better.
