The title says it all. I've been using Pluraleyes to sync hours of footage and when I try to frameserve with Debugmode I get the error: Unable to create signpost AVI file. Please close any applications that may be using this file and try again.
I'm thinking the culprit is Pluraleyes (other projects that I haven't used Pluraleyes on are unaffected by this error), but how exactly do I close it? I'm using Sony Vegas 9 Pro 64-bit. I don't see anything relevant under task manager processes that has the name "Pluraleyes" in it.
Or is there another way to get Debugmode to work without closing Pluraleyes? Would be a bummer if I had to create a Lagarith file just to send to my encoder. Hours saved from Pluraleyes would then be wasted on creating an intermediate file and I would like to avoid that.
Results 1 to 1 of 1
avi signpost to h264, colorspace and colormatrix
By codemaster in forum EditingReplies: 4Last Post: 20th Apr 2012, 10:49 -
how to create avi file from dvd
By videodude1966 in forum Video ConversionReplies: 1Last Post: 2nd Mar 2011, 18:12 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Unable to create chapters while converting from AVI to DVD using DVDAuthor.
By sumit_pankaj in forum Authoring (DVD)Replies: 7Last Post: 11th Jun 2009, 01:40 -
Not a valid avi file and Unable to insert......
By tommyboy9495 in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2007, 22:11
