  1. I have downloaded an AVI file, and when I try to encode it using the Panasonic encoder, it freezes up. I viewed the file, and about 1minute and 30 seconds into it, the video stops, but the sound continues. I can use the slide bar, and go around the freeze.
    Does anyone know of a way that I can get around the bad frame?
  2. Use virtual dub to edit out the bad frames, resave the video and try again. Can be time consuming but Works for me!
  3. Bugster, thanks. I tried that and it worked.
