OK,
I've looked at heaps of topics in here .. DL'ed TMPGEnc and played with it and VirtualDub and AVI2VCD yadda yadda yadda.
I have 2 Avi files (DivX?) 699 and 698 Megs in size.
The Audio is compressed I understand .. so I got the tracks to wav format using VD. (no! .. not the STD!)![]()
Got the avi Video to m1v and converted the Audio to mp2. How on EARTH do I get the result to VCD? .. tried TMPGEnc simple multiplex ends up 850megs. I tried to mpg to VCD same result .. I can't seem to get it to below 700megs .. HELP!!!! What am I doing wrong.![]()
Oh yes when I tried to get the 850 meg file to VCD via Nero as a test .. Nero complained that the audio stream was of the wrong type .. sigh!!![]()
The quality of the widescreen AVI file is astonishingly good (DL'ed from edonkey) but I can't seem to get it to VCD size .. please advise this 'noob' if you have the time.
TIA!![]()
elZee
I'll give that a try .. thanks for your reply :)try either telling nero it's a non standard vcd or try as an svcd...
elZee -
Well since I didn't get too many responses I concluded that it must have ben a dumb question .. ! :oops:
I re read the site and discovered exactly what I was looking for! :D
This is the link that fixed my dilema!http://www.vcdhelp.com/divxtovcd.htm
Thanks VCD Help .. this is a GREAT site! 8)
Cheers,
elZee - Happy VCD Camper!
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
Nero converting vob to avi,,,files way to big after????
By jcurrieirocz in forum Video ConversionReplies: 7Last Post: 17th Nov 2008, 20:41 -
cannot seek in big (>2 GB) XVID files
By adwiel in forum Video ConversionReplies: 1Last Post: 25th Jan 2008, 01:41 -
I'm new to Joining multiple avi files into one big file....
By Lahori82 in forum EditingReplies: 4Last Post: 29th Aug 2007, 14:05
