Hi, I'm a newbie at this sort of thing so forgive any stupidities I perpetrate. I regularly download 720p mkv files, and use xenonmkv to convert them into mp4s for streaming through an xbox360. Most of the time it works fine, but quite often there is an issue with the audio being out of sync - often by up to 10 seconds. I never know what is causing this, and usually just delete the mkv and look for another. It takes so long to download things and convert them it's truly depressing when they come out unsynched in this way.
Is there a simple solution, or better still - a simple explanation???
Many thanks
henryflower
There is a terrific simple solution, but you probably won't like it if you're like most people here. You could just buy a streaming media player that can handle MKV and stop trying to use Stone Age technology with your Xbox. Both the Xbox and PS3 have been eclipsed as media playback devices for over 3 years now. You could get on with your life without doing any conversions if you had a streaming media player that supported MKV files. Western Digital and many others make such devices.
As to why this is happening, I would guess that the audio in some files has a delay associated with it that xenonmkv does not respect when it converts, so the MP4 files get created with no delay which is wrong and causes the sync problem. -
jman, that's a damn good suggestion. I might just do that, thank you.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
MKV to MP4 encoding_hardsubbing and audio sync problems.
By Alcatraz in forum Newbie / General discussionsReplies: 11Last Post: 16th Mar 2012, 16:34 -
Problem with audio sync with an mp4/converting an mkv.
By Clowmet in forum Video ConversionReplies: 0Last Post: 21st Aug 2011, 09:58 -
Why video and audio out of sync while playing .mp4 and .mkv files?
By Bonie81 in forum Software PlayingReplies: 0Last Post: 6th Apr 2010, 19:03 -
Fixing audio sync issues when using GOTSent to convert MKV to MP4
By darrklight1138 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2009, 07:56
