  1. Hi guys
    I just want to show some of my work restoring a vhs tape. You can see how important is to use a good svhs player to transfer
    Screenshot using a simple vhs player
    http://www.youtube.com/watch?v=EUargFCbVgc
    And sample here http://www.megaupload.com/?d=K0G90QIB
    Using a Panasonic AG-1980 the quality increases a lot , but still some image erros are noticeable
    And sample here http://www.megaupload.com/?d=CZ6L80V7
    After some work with avisynth scripts and virtualdub the results are amazing, better than i expected
    http://www.youtube.com/watch?v=JlU8GkV5AhI
    And the video here http://www.megaupload.com/?d=B3ZUE99A
    I still have some problems with color correction, i use Premiere cs5 filters for that, anyone knows a good tutorial for color correction using Premiere?
  2. Banned
    New York, US
    Adobe Premiere has a user guide, which is where you should start. There are many free Adobe color correction tutorials on the internet, most of them aimed at photography -- but the tools and techniques are the same. Here are two examples:
    http://www.peachpit.com/articles/article.aspx?p=101197&seqNum=6
    http://www.photoshopessentials.com/photo-editing/levels-curves/
    Here is a free Adobe guide to histogram work with Adobe After Effects. Adobe has similar guiides for other products. (Do the tools for AE appear similar to those in Premiere and Photoshop? Most of them are).
    http://help.adobe.com/en_US/AfterEffects/9.0/WSB1713828-3801-4025-B9E6-E87E487AD828a.html
    You can use many of the same techniques with VirtualDub plugins (try ColorMill and the Gradation Curve for starters).
    I had time only for the 3rd video. The color shots of the man talking are over-sharpened. I see bright ringing along edges; the video and the image of him have very few smooth gradations between brights, midtones, and shadows; the man's skin lacks subtle shadings and looks plastic. The bottom image has a color imbalance toward the blue side of magenta; his hair and lips are purple, shadows are too blue (look at his shirt collar). Contrast is too high. Many brights are 20 RGB points above spec and look unnatural.
    The link below will get you a free Csamp.exe pixel color sampler that you can place on your desktop -- read pixel RGB values in VirtualDub and in images, the same way you've been reading pixel values in Premiere to analyze color problems:
    http://www.netreach.net/~gavin/gavsfreeware/csamp.htm.
    Don't forget to calibrate your monitor. An EyeOne Display 2 or Display LT is the way to go.
    The third image is over-processed and has created new errors.
    sanlyn covered it pretty well.
  4. Originally Posted by sanlyn View Post
    http://www.netreach.net/~gavin/gavsfreeware/csamp.htm..
    I prefer Mzoom personnally, it give you RGB colors AND also secondary Colors Cyan,Magenta,Yellow and let's not forget the Black !
    Not free though
