    Feb 2007
    Italy
    Hi, I want to burn some MKV files with ImgBurn 2.5.5.0 but doesn't work.
    I mean the burning process works fine, but my Blu-Ray Disc Player LG BD550 doesn't recognize the burned MKV file.
    The same MKV file works fine if played from external USB drive.
    Maybe something's wrong with the ImgBurn settings?
    Here's the MKV file info generated with MediaInfo:
    General
    Unique ID                        : 223132836867042904709617178605442047352 (0xA7DDD23ACEB758B4BF93A947D34C1D78)
    Complete name                    : C:\Users\User\Desktop\Sample.mkv
    Format                           : Matroska
    File size                        : 4.37 GiB
    Duration                         : 1h 34mn
    Overall bit rate                 : 6 648 Kbps
    Encoded date                     : UTC 2011-04-18 12:50:03
    Writing application              : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
    Writing library                  : libebml v1.2.0 + libmatroska v1.1.0
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : High@L4.1
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 4 frames
    Codec ID                         : V_MPEG4/ISO/AVC
    Duration                         : 1h 34mn
    Nominal bit rate                 : 5 716 Kbps
    Width                            : 1 280 pixels
    Height                           : 540 pixels
    Display aspect ratio             : 2.35:1
    Frame rate                       : 23.976 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.345
    Writing library                  : x264 core 114 r1913 5fd3dce
    Encoding settings                : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5716 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
    Language                         : English
    Audio #1
    Format                           : AC-3
    Format/Info                      : Audio Coding 3
    Mode extension                   : CM (complete main)
    Codec ID                         : A_AC3
    Duration                         : 1h 34mn
    Bit rate mode                    : Constant
    Bit rate                         : 224 Kbps
    Channel(s)                       : 2 channels
    Channel positions                : Front: L R
    Sampling rate                    : 48.0 KHz
    Bit depth                        : 16 bits
    Compression mode                 : Lossy
    Stream size                      : 151 MiB (3%)
    Title                            : AC3 2.0 @ 224 Kbps
    Language                         : Romanian
    Audio #2
    Format                           : AC-3
    Codec ID                         : A_AC3
    Duration                         : 1h 34mn
    Bit rate                         : 640 Kbps
    Channel(s)                       : 6 channels
    Channel positions                : Front: L C R, Side: L R, LFE
    Bit depth                        : 16 bits
    Stream size                      : 431 MiB (10%)
    Title                            : AC3 5.1 @ 640 Kbps
    Language                         : English
    Audio #3
    Format                           : AAC
    Format/Info                      : Advanced Audio Codec
    Format profile                   : LC
    Codec ID                         : A_AAC
    Duration                         : 1h 34mn
    Title                            : AAC 2.0 @ 64 Kbps
    Language                         : English
    Text #1
    Format                           : UTF-8
    Codec ID                         : S_TEXT/UTF8
    Codec ID/Info                    : UTF-8 Plain Text
    Language                         : Romanian
    Text #2
    Format                           : UTF-8
    Language                         : English
    Menu
    00:00:00.000                     : :Chapter 01
    00:02:23.268                     : :Chapter 02
    00:03:02.807                     : :Chapter 03
    00:06:41.025                     : :Chapter 04
    00:10:10.484                     : :Chapter 05
    00:12:40.050                     : :Chapter 06
    00:15:57.790                     : :Chapter 07
    00:16:45.754                     : :Chapter 08
    00:18:07.169                     : :Chapter 09
    00:20:44.660                     : :Chapter 10
    00:25:41.873                     : :Chapter 11
    00:27:06.041                     : :Chapter 12
    00:29:10.457                     : :Chapter 13
    00:31:26.217                     : :Chapter 14
    00:35:13.611                     : :Chapter 15
    00:38:08.369                     : :Chapter 16
    00:40:12.201                     : :Chapter 17
    00:42:38.347                     : :Chapter 18
    00:45:14.044                     : :Chapter 19
    00:46:20.778                     : :Chapter 20
    00:49:32.302                     : :Chapter 21
    00:52:52.586                     : :Chapter 22
    00:54:08.662                     : :Chapter 23
    00:58:29.631                     : :Chapter 24
    01:01:50.790                     : :Chapter 25
    01:04:59.020                     : :Chapter 26
    01:08:53.796                     : :Chapter 27
    01:11:09.848                     : :Chapter 28
    01:12:00.482                     : :Chapter 29
    01:13:05.381                     : :Chapter 30
    01:14:20.789                     : :Chapter 31
    01:17:04.578                     : :Chapter 32
    01:19:25.051                     : :Chapter 33
    01:22:17.682                     : :Chapter 34
    01:25:10.522                     : :Chapter 35
    01:26:52.415                     : :Chapter 36
    Aug 2002
    South Florida
    What makes you think the LG plays MKV?
    Feb 2007
    Italy
    The European version plays MKV files:
    http://www.lg.com/it/tv-audio-video/video/LG-BD550.jsp
    ..and like I said ''The same MKV file works fine on LG-BD550 if played from external USB drive. ''
    I would guess because "The same MKV file works fine if played from external USB drive."
    In what burning mode are you burning? I guess UDF? Try UDF/ISO mode. Or maybe it just doesn't support mkvs on dvdr media.
    Feb 2007
    Italy
    Ok, tried the UDF, now I'm trying the UDF/ISO mode. Thanks.
    Feb 2007
    Italy
    Fixed! I reinstalled ImgBurn and now it works fine. The problem was my settings:
