With over 30 hours of render time staring me in the face, plus the fact that the CPU usage averages only about 30%, it's time for me to figure out why the VDub+Avisynth combination isn't making better use of the CPU, and what I can do about it.
Using the latest non-mod VDub, and Avisynth 2.6 multithread. All four cores are being used pretty much equally. Usage varies wildly over time, from as little as 15% to as much as 50%.
Avisynth (even the MT version) does not multithread by default - you have to add appropriate commands to tell it to do so. See http://avisynth.org/mediawiki/MT_support_page.
I see from the script posted in your other thread that you are not doing this, so any multithreading you are getting is coming solely from your encoder, not from Avisynth.
Try changing your script to this:
Import("c:\Program Files (x86)\AviSynth 2.5\plugins\DeStripe.avs")
SetMTMode(5)
AVISource("file.avi")
AssumeTFF
SetMTMode(2)
ConvertToYV12(interlaced=true)
QTGMC(preset="Very Slow", sharpness=0.5)
DeStripe(rad=2, offset=1, thr=16)
Also see the QTGMC documentation for hints on multithreaded use. -
"An exception occurred in module 'KERNELBASE'."
With your advice in hand, I was able to find a relevant topic and have toyed around with SetMTMode at length. In a nutshell, there is no combination of SetMTMode(5,x) / EdiThreads=y that does not cause the above error in VirtualDub. Not even SetMTMode(5,1). Observation of CPU usage when I attempt to load a video does show that it is being used more fully (with the exception of when I specify fewer than three cores), and at very low settings (lower than even the CPU usage I've gotten without SetMTMode), it will sometimes render the first frame, but anything beyond that causes the crash.
Edit: No component in my PC is overclocked. -
I don't know anything about DeStripe, but it may be that it is incompatible with multithreading, or at least with mode 2 - many filters are. Try taking out DeStripe to see if that is the source of the error.
If that is the case, it might be made to work if you add SetMTMode(5) before the call to DeStripe (or even try mode 3 or 4). -
Good suggestions. Actually I had already tried eliminating everything, and even using QTGMC in every mode besides 2. It's that combination of QTGMC and SetMTMode that just isn't working under any circumstance.
Buy more computers, KVM them, and learn to wait.
That's what the rest of us have to do.
There's really no way around it. Not everything can use mt or multi cores.Want my help? Ask here! (not via PM!)
While it's true that Avisynth MT can often be a hit-and-miss affair (someone once described it as a 'crap shoot'), many people are successfully multithreading QTGMC.
One thing to check is that you have the correct versions of all needed plugins - in particular, for your Avisynth version, you need the 2.6-compatible variant of MaskTools, mt_masktools-26.dll, not the '25' variant.
Also, have you tried experimenting with SetMemoryMax usage (as described in QTGMC doc)?
AviSynth & VirtualDub - Comfortable ways to create avs-files?
By klischee in forum EditingReplies: 7Last Post: 28th Oct 2010, 17:20 -
how to speed up rendering time with HD video
By The Linguist in forum Newbie / General discussionsReplies: 1Last Post: 17th Dec 2009, 06:31 -
FCP 6: Question about rendering speed and time
By wheelandtorque.com in forum MacReplies: 5Last Post: 19th Oct 2009, 15:24 -
How to speed up rendering time in Vegas? PS3
By Abiyad in forum EditingReplies: 4Last Post: 25th Jan 2008, 18:45 -
Adobe Premiere project using AVISynth AVS scripts crashes when rendering!
By Mark001 in forum EditingReplies: 2Last Post: 11th Jun 2007, 00:25
