All of a sudden today, when using firefox 4 after clicking on a link it opens up on my second monitor instead of the 1st one. It only does this from this one site, but I have been unable to get it to open the links onto my main monitor. I have done the take webpage out of full screen and move it to the 1st monitor and then hit the "X" to close it, but they just keep opening on the 2nd monitor, tried holding shift+"X" as well as ctrl+"X" and still just opens on the second screen. Any ideas?
What We Do In Life, Echoes In Eternity....
Try this. It's a trick that worked on older versions, but I assume it still works.
Close Firefox
Find localstore.rdf in C:\Users\<USERNAME>\AppData\Roaming\Mozilla\Firefo x\Profiles\<SOMESTRINGOFLETTERSANDNUMBERS>.default
Move it somewhere else (or rename it)
Open Firefox
Firefox should then create a new localstore.rdf file. It contains such things as window position and size (they should be reset to default values).
Once you are sure that Firefox has created a new localstore.rdf file, you can safely delete the old one.valvehead//
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
Firefox?
By AM3 in forum ComputerReplies: 1Last Post: 23rd Apr 2008, 13:35 -
Tutorial CD problem- Links are opening folders instead playing the content
By src2206 in forum ComputerReplies: 17Last Post: 23rd Oct 2007, 00:00 -
What's up with Firefox?
By ahhaa in forum ComputerReplies: 8Last Post: 4th Aug 2007, 00:09 -
mIRC Links in Firefox
By Xenogear900 in forum ComputerReplies: 1Last Post: 15th May 2007, 12:52
