I've converted a DVD to mpeg using Flask, and then I use nero to create the VCD.
I was under the impression that an 80min CDR can hold close to 80min worth of VCD. I used TMPEGenc to chop a 131min movie into two ~65min section, when I drag the file into the VCD screen in Nero it says that the file is 93min long and won't burn it.
Is there a way around this or does nero put some overhead-data on the VCD?
Anyhelp is very much appriciated
