    May 2009
    I've got about a dozen different things which need to be rendered off. They pretty much have to be done in VirtualDub because I want to keep the colorspace YUV for now. Each one takes about three hours to complete, and before I start each I have to set up begin/end points to save render time.
    Since I am looking at literally days of rendering, and I won't be staring at the computer all of the time, it makes sense to try to set up a batch render if I can. Is this even possible?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Look for job control and batch operation. It does have the function. Its under the file menu. It might be worded slightly different from the version I used to look it up (plain vdub from a early 2010 release - I don't use it on this computer I'm typing on - old single core reserved for surfing).
    May 2009
    Yeah, I see Job Control. There is an astonishing lack of how-to information on that function. Like how do I tell it I've got my edit points set up and I'm ready to add a "save as AVI" to the list? I'll keep looking.
    May 2009
    Think I got it. There's a lot of arbitrary menu inconsistency between Vdub iterations but I believe I found what I needed. Thanks.
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    Glad you got it.
    Yes as good as virtualdub is the software layout is quite a bit different between each altered version.
