I am tring to find an dvd/audio system that can output 2 audio languages at the same time. My wife would like for us to watch some movies with her parents who only understand Italian. I dont like to watched dubbed movies, the voices are always so diffrent and dont sync most of the time. I would like to be able to use headphones that with a selector you can select the language you want from the dvd player something like output 1 and output 2. My question is does this system already exist? If so, what is the brand/model or is there pc software that can do this? Thank you in advanced
dmk
There really doesn't exist the type of system you're looking for in a prepackaged form (at least YET, some things like this are in the works).
What you could do though is:
1. Use a software DVD player on a PC
2. Use a PC that has surround outputs (many have outputs for Front L+R, Rear L+R, C+Sub on headphone jacks)
3. Using a multichannel audio editor (like wavosaur), take your English track and put it on the Front channels, and your Italian track and put it on the rear channels and save as a multichannel file (WAV, AC3)
4. Remux/reauthor this track into a new/revised DVD title.
5. Plug the English listeners into the Front-channels' jack and the Italian listeners into the Back-c hannels' jack (using Y-cables if you need multiple headphones)
A similar thing could be done by putting the EN track on the left and the IT track on the right and just position speakers close to the separate listeners.
Synchronize Audio and Video from Different Sources
By Bruno AUgusto in forum AudioReplies: 2Last Post: 22nd Nov 2011, 19:27 -
Recording multiple audio sources in realtime
By Cyber Akuma in forum Newbie / General discussionsReplies: 12Last Post: 5th Mar 2010, 22:44 -
Mux & sync audio from different sources
By RWANDREWS in forum AudioReplies: 1Last Post: 9th Jan 2009, 11:06 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19 -
Joining audio from 2 differant sources
By kshavo in forum AudioReplies: 2Last Post: 6th Nov 2007, 10:34
