Hi,
i have a little game of scrabble on my pc,and i really like the background music whilst the program is running.
Is it possible to remove the music from the program and use purely as a music track?
There is a bin image file in the folder size 6,961
Ita a longshot,and i havent a clue if it can be done,
thanks...Pensioner
Just because something has an extension *.BIN doesn't necessarily make it a DiscImage file format. It could just as easily, or even more likely, be a "BINARY" (and proprietary) format. If it is, use ISOBuster to read it and see whether there is "discimage" contents in it.
If that doesn't work, do a "What-you-hear-is-what-you-get" Audio cap while you're playing the game...
Scott -
You can also try a search on Google and use the particular game's name that you have with a search such as
"how to rip sound from whatever version of pc scrabble".
Perform searches of that nature. A lot of people have made programs for doing such things for a number of pc games and you never know until you check
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 02:07 -
Any programs that can extract an .IBQ image file for me?
By Bansaw in forum Newbie / General discussionsReplies: 3Last Post: 17th Jun 2011, 14:03 -
Mplayer image extract: my TGA is blue!
By RogerTango in forum Video ConversionReplies: 0Last Post: 30th Apr 2011, 13:11 -
How to extract music only?
By UncleBose in forum AudioReplies: 11Last Post: 14th Nov 2009, 08:51 -
Extract special CD-music to harddrive
By Blå_Mocka in forum AudioReplies: 3Last Post: 21st Jul 2007, 06:51
