I came here with this issue that I've read can be fixed by saving your preferences as default:
AVStoDVD inexplicably reverts to PAL even after setting DVD standard in preferences to NTSC (and proceeds to burn a PAL DVD).
Even though I save my preferences...save the project and try and get it to go with NTSC, it refuses. I'm running 2.3.4 on a Windows XP Pro machine.
Any advice?![]()
"Options", "Preferences", "video", Select NTSC D1 (or your choice); select box "save current preferences as default" after you've set your choices. This should apply when you start your next project.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Sure enough...there it be....
starting over again...thanks so much for being so quick with an answer. -
I had to find it myself - I only started with the program today, just downloaded and installed. Mine was defaulted to PAL as well.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
ntsc tapes pass through pal camcorder into mac for ntsc playing?
By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 17:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
